Hello!
I have a problem that when i leave my measuring station running for over a long period of time, the values are sometimes shifted in the middle of the data file - not in the right column. (see added picture of the file)
For example, I get 3 hours of normal data in the right columns, than the values shift a column to the right (or left), and I get these shifts in the file, just a couple of lines, and then the values go back to normal. Sometimes I lose one hour of data at that shift point and then the values get back again in the right columns for another 12h.
I am running SDfat library, and I have a switch that closes the file, before I remove the SD card.
I tried different code variations, but this seems to happen at random.
I am also adding the code (in attachment) that I am running on my arduino UNO, that has 3 different sensors and an LCD and this SD card slot shield.
Any help would be greatly appreciated. Thank you.
_3s_switch_Sdfat_noSerial.ino (6.53 KB)
