Writting to an EEPROM memory always returns last value written [SOLVED]
Hi folks, can someone spot the mistake on my code?
#include <Wire.h>
#define DEVICEADDRESS   0x57
uint8_t myvar1 = 0b00011000;
uint8_t myvar2 = 0b11100111;
int temp = 0;
int temp1 = 0;
Wire.begin();
  EepromWrite(0x05, myvar1);
  delay(10);
  EepromWrite(0x10, myvar2);
  temp = EepromRead(0x05);
  delay(50);
  temp1 = EepromRead(0x10);
  Serial.println(temp);
  Serial.println(temp1);
  delay(2000);
void EepromWrite(uint16_t theMemoryAddress, uint8_t u8Byte)
    Wire.beginTransmission(DEVICEADDRESS);
    Wire.write( (theMemoryAddress >> 8) & 0xFF );
    Wire.write( (theMemoryAddress >> 0) & 0xFF );
    Wire.write(u8Byte);
    Wire.endTransmission();
    delay(5);
uint8_t EepromRead(uint16_t theMemoryAddress)
  uint8_t u8retVal = 0;
  delay(5);
  Wire.requestFrom(DEVICEADDRESS, 1);
  u8retVal = Wire.read();
  return u8retVal ;
This is my output:
11100111
11100111
Seems as the value written is always "myvar2" or I am always retrieving the last value.
Could you check the return value of the Wire.endtransmission?
It shows if the call really does work.
  Wire.write(u8Byte);
  int x = Wire.endTransmission();
  Serial.println(x);
  delay(5);
  Serial.println(x);
  delay(5);
  return u8retVal ;
loop() might be missing one delay() // neverthought I would say that :wink:
  delay(10);
  delay(10): // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<  ??
  delay(50);
  delay(2000);
You need a delay between the write and the read.
same idea, but the eepromWrite has already a 5 millis delay()
What EEPROM are you using, can you post a link to the datasheet?
robtillaart:
Im using this FRAM:
I placed the delays just in case someone wanted to try the code on a actual EEPROM
robtillaart:
Returns:
0
0
0
0
231
231
do you have pull up resistors connected?
robtillaart:
Yes, 100% Software issue.
did you see in the datasheet that this particular FRAM you use has only an 8 bit memory address, not a 16 bit ??
4Kbit = 256 bytes ==> 8 bits address..
the problem might be that you write both values to address 0x00 ..
can you try this code instead of the EEPROMwite/read?
void FRAMWrite(uint8_t theMemoryAddress, uint8_t u8Byte)
  Wire.write( (theMemoryAddress);
  Wire.write(u8Byte);
uint8_t FRAMRead(uint16_t theMemoryAddress)
  return Wire.read();
There is a 9th address bit in bit 1 of the 8 bit slave address byte (i.e. bit 0 of the usual 7 bit address passed to the wire library). That allows selection of the bottom or top 2Kbits.
robtillaart:
Now, how could i not see that :astonished:
Hackscribble:
Ok, so I write 0x56 for half and 0x57 for the other half?
That's right - you have pins A1 and A2 on the FRAM pulled high?
Confirmed.
Thanks to everyone for helping "digest" the information.
I can confirm the device is working with a single address byte and that by selecting the correct address for A0 (on the code) I can access the top or bottom 2K locations
Hackscribble:
Yes, there are physical pull ups from the previous EEPROM pulling the pins high
so that would make
  uint8_t addr = DEVICEADDRESS;
  if (theMemoryAddress > 127) addr++;
  Wire.beginTransmission(addr);
  Wire.write(u8Byte);
  return Wire.read();
