Wrong analogRead values
Try this: (Compiled but untested.)
const int numReadings = 100;
const int analogInPin = A0;
int inputReading [numReadings];
  for (int i = 0; i < numReadings; i++) {
    inputReading [i]= analogRead(analogInPin); // roughly 9kHz sampling
    float voltage = ((inputReading[i]/1023.0)*5.0);
    Serial.println(voltage);
Unplug it! It'll go to zero. (or pretty close) 8)
Learning:
Bonus marks to Learning if you can explain why those sunglasses are unearned. 8)
(Hint: have you tried it?)
Learning:
No it won't it will float which is why I suggested you need a load resistor. So why have you not tried this.
Better still put the scope lead on the analogue input and run the code again. Is it different than when the scope is disconnected.
AWOL:
I tried connecting a 10k resistor as someone suggested. And it WORKED !. I uploaded your code for fun and it also works. Its a bit better than mine.... :frowning:
As some one once said, tell me when I am wrong not when I am right 8)
Cool glasses justified I think.
