I recently purchased a DIYMORE clone Arduino UNO (replacing genuine one I blew up)
It has ATMEL M328P chip and WKH CH340 USB chip
Using Windows 10
I could not get this to work
Errors about not in Syn and Programmer not responding. Loop test failed. Ensured correct board and COM selected. Tried different PC. No go
I reinstalled CH340 driver (though my Mega 2560 with same chip worked OK)
I reinstalled IDE
Nothing would allow upload
Then I saw YouTube suggestion to try different board names in IDE
Found that board works (at least with simple 'Blink' test - haven't tried more complicated developed sketch) by selecting in IDE Pro or Pro Mini. Also works by selecting Lilypad Arduino (although stops with error in upload but after a second successfully uploads.
If all I have to do is remember to select Pro or Pro Mini and it works, I don't care
This might be helpful info for others with clone problems
How can this happen? Has the wrongly named bootloader been loaded to M328P chip. Can I re-burn to correct it (though why bother)?
It could be that it's using the wrong bootloader, which is set to communicate at 57600 baud.
It could be that it's using the normal Uno bootloader, but the microcontroller is running at 8 MHz instead of the expected 16 MHz, which means that you need to communicate with the bootloader at 1/2 (8 MHz / 16 MHz) the normal baud rate: 115200 baud * 1/2 = 57600 baud. That could be caused by the microcontroller using the internal 8 MHz oscillator instead of the usual external 16 MHz resonator, or that the external clock is 8 MHz instead of the usual 16 MHz.
You could easily check this by setting Tools > Board > Arduino Pro or Pro Mini and Tools > Processor > ATmega328P (5V, 16 MHz), uploading Blink, then checking whether the LED blinks at 0.5 Hz (1 second on, 1 second off), or 0.25 Hz (2 seconds on, 2 seconds off). If the blink is at half the expected speed of 0.5 Hz then you know the clock is 8 MHz.
Did as you suggested and 1 sec on 1 sec off is maintained.
Also red text at bottom of IDE says Over riding to 57600 baud
Oscillator on board marked as 16000
So I guess all will be OK if I just select Pro or Pro Mini
My application is to operate stepper motors on a robotic arm so operating frequency is not critical to me
Selecting Lilypad Arduino also shows over riding to 57600 baud but blink rate is twice speed - half sec on half sec off
Having to select other than UNO (when it is supposed to be a UNO) in IDE is a trap for buyers and not documented widely
wandiligong:
Looks like the idiots who made the clone put the wrong bootloader on it.
wandiligong:
This doesn't affect the operating frequency.
wandiligong:
That's because the Lilypad is a 8 MHz board so the code thinks the microcontroller is running half as fast as it really is.
wandiligong:
If the board was properly made, this would never be an issue. So the only place it needs to be documented is by the manufacturer and sellers of the faulty product. Or, better yet, they could just make it right in the first place.
wandiligong:
Yes.
wandiligong:
Using the Uno bootloader frees up 1.5 kB of precious flash memory.
