Hey guys,
I am trying to build a buttonbox for Elite Dangerous.
Using the Arduino micro Pro board with pushbuttons and rotary encoders.
I connected all buttons and encoders. Uploaded the sketch.
And with every button I push or encoder I turn the 'TX' led lights up sending a character.
But the characters are not the ones I put in the matrix.
I get random characters instead of the ones I put in the sketch.
Can this be related to the keyboard.h file?
Here is the sketch I am trying to get working.
#include <Keypad.h>
#include <Keyboard.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 25
#define NUMROWS 5
#define NUMCOLS 5
//define the symbols on the buttons of the keypads
char buttons[NUMROWS][NUMCOLS] = {
{'q','w','e','r','t'},
{'y','u','i','o','p'},
{'a','z','d','f','g'},
{'h','j','k','l','m'},
{'x','c','v','b','n'},
struct rotariesdef {
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;æ³²ú®é塤©
rotariesdef rotaries[NUMROTARIES] {
{0,1,KEY_RIGHT_ARROW,KEY_LEFT_ARROW,0},
{2,3,KEY_DOWN_ARROW,KEY_UP_ARROW,0},
{4,5,KEY_PAGE_UP,KEY_PAGE_DOWN,0},
{6,7,KEY_HOME,KEY_END,0},
//Encoders code from Ben Buxton
//More info: http://www.buxtronix.net/2011/10/rotary-encoders-done-properly.html
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#define R_CW_FINAL 0x1
©#define R_CW_BEGIN 0x2
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
byte rowPins[NUMROWS] = {21,20,19,18,15}; //connect to the row pinouts of the keypad
byte colPins[NUMCOLS] = {14,16,10,9,8}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Keyboard.begin();
rotary_init();
CheckAllEncoders();
CheckAllButtons();
void CheckAllButtons(void) {
char key = buttbx.getKey();
if (key != NO_KEY) {
Keyboard.press(KEY_LEFT_CTRL);
Keyboard.press(KEY_LEFT_ALT);
Keyboard.press(key);
delay(150);
Keyboard.releaseAll();
}//Keyboard.write(key);
/* Call this once in setup(). */
void rotary_init() {
for (int i=0;i<NUMROTARIES;i++) {
pinMode(rotaries[i].pin1, INPUT);
pinMode(rotaries[i].pin2, INPUT);
#ifdef ENABLE_PULLUPS
digitalWrite(rotaries[i].pin1, HIGH);
digitalWrite(rotaries[i].pin2, HIGH);
#endif
/* Read input pins and process for events. Call this either from a
* loop or an interrupt (eg pin change or timer).
* Returns 0 on no event, otherwise 0x80 or 0x40 depending on the direction.
unsigned char rotary_process(int _i) {
unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
unsigned char result = rotary_process(i);
if (result) {
Keyboard.write(result == DIR_CCW ? rotaries[i].ccwchar : rotaries[i].cwchar );
