Wrong date/time (time zone) in dir index vs. linux date
I have wrong time information GMT instead of GMT+1 (1h off) in the "last modified" section of the directory index.
E.g. I call http://openhive.local/sd/test/ I get
Index of /sd/test/
    modified: Wed, 17 Feb 2016 21:01:37 GMT
    directory - 32.00 kbyte
    test.txt
    modified: Wed, 17 Feb 2016 21:02:35 GMT
    text/plain - 0.00 kbyte
But my shell output is
root@ArduinoYun:/mnt/sda1/arduino/www/test# ls -al
drwxr-xr-x    2 root     root         32768 Feb 17 22:02 .
drwxr-xr-x    4 root     root         32768 Feb 17 22:01 ..
-rwxr-xr-x    1 root     root             5 Feb 17 22:02 test.txt
22:02 is the correct time. I get also this time in luci on the tab System > System > local time
Local Time: Wed Feb 17 22:21:19 2016
Time zone is Europe/Berlin, this means GMT**+1**
How can I set the offset of +1 in the webserver? Or is this not possible and time in dir index is always GMT?
Yun use uhttpd as web server.
static char * uh_file_unix2date(time_t ts)
	        static char str[128];
	        struct tm *t = gmtime(&ts);
	        strftime(str, sizeof(str), "%a, %d %b %Y %H:%M:%S GMT", t);
	        return str;
https://dev.openwrt.org/browser/trunk/package/uhttpd/src/uhttpd-file.c?rev=32704
It is hard code as GMT time zone. You need rewrite it and cross compile it.
