Wrong ethernet module? 12 pins on ENC28J60
Attempting my first network connection to my pro mini clone and I am not finding the correct pins on my ethernet module (see pic).
Most modules have (10) pins, but this one has (12). The kicker is that there is no SI pin, and a bunch of pins that are unknown to me. LNT ST Q3
Of course, the seller is overseas and could not provide any help/pinout/specification sheets aside from this brief description:
Brand new and high quality.
chip board ENC28J60-I/SO.
the board 25MHZ crystal.
the network interface board HR911105A.
3.3 V power supply pin.
Size:5.2cm x 1.9cm - 2.05inch x 0.75inch.
I am under the assumption that this is an unusual and possibly mis-identified module. I want to ask if anyone has any experience with it before I proceed. If this hardware is discussed elsewhere I apologize for being unable to find it (there is a plethora of the info for the 10-pin modules).
I will try the following pin translation when I free up later this week:
LNT = INT
ST = SI
Q3 = 3.3V
If anyone has had any experience with the 12 pin version please chime in. If it is just silkscreen errors that would be great.
I've tested with a digital multimeter:
LNT = INT
ST = SI
Q3 = 3.3V
Sorry for asking, but did you find out the wiring scheme of this 12 pins Ethernet and the arduino uno?
Hello, I have the same problems. Any solution?
I bough this component too, I couldn't make it work!!! I tried several libraries but it didn't work, I tried to edit some .cpp and .h files, but no success.
I have a mega2560, the IDE I used was 1.0.5 and the last one 1.6.4.
Were you able to make it work???? How did you do??
thank you very much
It works!!!
Configuration:
IDE: 1.0.6
Library: ethercard (https://codeload.github.com/jcw/ethercard/zip/master)
Sketch: Examples/ethercard/backSoon
Arduino: Duemilanove
12 Pins ENC28J60 Module: HanRun HR911105A 14/10 (module.jpg)
Power Supply (power_supply_1.jpg and power_supply_2.jpg)
Wiring:
Arduino Module
digital 12 SO
digital 11 ST
digital 13 SCK
digital 8 CS
5V 5V
Gnd GND
It was not working until I plugged the power supply!
I hope it will help…
Gildas:
It works!!!
Configuration:
IDE: 1.0.6
Wiring:
Arduino Module
digital 12 SO
digital 11 ST
digital 13 SCK
digital 8 CS
5V 5V
Gnd GND
With 3.3V (pin "Q3") works too.
