12
wrong File
121
wrong File
120
wrong File
13
wrong File
13
wrong File
12
wrong File
14
wrong File
110wrong File
#include <SD.h>
#include <EEPROM.h>
#include <SD.h>
String buffer;
int latchPin = 5 ; // Pin connected to ST CP of 74HC595
int clockPin = 7 ; // Pin connected to 58 CP of 74HC595
int dataPin = 6 ; //// Pin connected to 05 of 74HC595
/// POTENTIOMETER FOR TIME DELAY ////////////////////
const int PotTime = A1 ;
int Potvalue = 0 ; // The actual Fot value
int PotmapValue=100 ;// Mapped output value milisecond
// LCD STUFF
#include <LiquidCrystal.h>
// Pines para el LCD
#define LCD_RS A5
#define LCD_Enable 9
#define LCD_D4 2
#define LCD_D5 3
#define LCD_D6 4
#define LCD_D7 8
//Initialize
LiquidCrystal lcd(LCD_RS,LCD_Enable,LCD_D4,LCD_D5,LCD_D6,LCD_D7);
/*----------BUTTON DECELERATION-----------*/
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
/*---------(Deklarasi varibel) -----------*/
int lcd_key = 0 ;
int adc_key_in =0 ;
int adc_key_prev = 0 ;
int read_LCD_buttons ()
adc_key_in=analogRead (A0) ;
// delay ( 5 ) ;
// int k = ( analogRead ( A0 )_adc_key_in ) ;
// if ( 5 < aba ( k ) ) return btnNONE ;
if ( adc_key_in > 1000 ) return btnNONE ;
if ( adc_key_in < 50 ) return btnRIGHT ;
if ( adc_key_in < 195 ) return btnDOWN;
if ( adc_key_in < 380 ) return btnSELECT ;
if ( adc_key_in < 555 ) return btnUP ;
if ( adc_key_in < 790 ) return btnLEFT ;
return btnNONE ;
boolean Nextfile =false ;
boolean Previousfile = false ;
/*////LETS DEFINE THIS SKETCH FOR NIMSER OF SOLENOID VALVE
1 mean 8 Solenoid valves
2 means n×8 solenoid valves */
int solenoid =1 ;// change this number to run more then 8 valve
// READ FILE STATISICS I
int Total_number_of_lines = 0 ;
boolean WrongbyteData = false ;
///////// SD BELATED STUFF // mmmmmm
File sd_root ;
File sd_file ;
#define max_name_len 13
#define max_num_Files 40
unsigned char num_Files= 0 ;
unsigned char current_File = 0 ;
char file_Name[max_name_len]; // fn
#define sd_cs 10 // chip select ' line for the microad card
void sd_card_setup ()
if (!SD.begin(sd_cs))
//lcd.clearDisplay ( ) ;
Serial.println ( " sd card failed \ nor not present " ) ;
//lcd.display ( ) ;
return ;
sd_root=SD.open ("/") ;
//Serial.println("sd card root open " ) ;
if (!sd_root)
//lcd.display ( ) ;
return ;
/*//*IETS UPLOAD ALL 40 FILES TO EEPROM. *
* *THIS TO BE CHECKED EACH TIME WE LORD THE SD CARD
*WEMOST HAVE A FUNCTION TO ERASE THE MEMORY I THINK
* IRPUTURE E MILL CECK THE CONTET OF EACH FILE AND DISCARD THE FILE BASED ON WRONG BYTES DATA m */
void sd_dir_setup ()
num_Files = 0;
// sd_root = SD.open ("/");
sd_root.rewindDirectory ();
while (num_Files < max_num_Files)
//break out of while loop when we check all file (past the last entry).
File entry =sd_root.openNextFile();
boolean EndofLine=false;
//Serial.peint (entry.name ());
if (!entry)break;
// Serial.print (num_Files);
//Serial.print (entry.name() ) ;
WrongbyteData=false;//Make ie false for every new file
//LETS SEE THE CONTENTS OF FILE SUITABLE AND DISCARD IF RONE BYTE DATA
while (entry.available ()>0) //read from the file until there's nothing else in it:
buffer = entry.readStringUntil('\n');
//read uptil new 1ine character meet i.e. Line by Line
Serial.print (buffer);
// Serial.printin("Buffer Length: ");
//Serial.print (buffer.length()-1);
if ((buffer.length ())==1)
Serial.println("End of Line Detected");
EndofLine =true;
goto lup1;
if (((buffer.length()-1)!=solenoid)&&(EndofLine==false))
Serial.println("wrong File");
WrongbyteData=true;
// entry.close ();
lup1:
if (entry.name () [0] == '-' ||entry.name() [0]=='-' || entry.isDirectory ())
continue ;
char i ;
for (i=max_name_len - 5;i> 0;i--)
if (entry.name () [i] =='-') break;
i++ ;
/*This only stoe *.KFK FILES IN EEPROM (for now)
if you add other file types. you should add their extension here. */
if (( entry.name()[i]='T' && entry.name()[i+1] =='X'&& entry.name()[i+2]=='T')&& WrongbyteData==false) //||(p.name ()[i]=='W '&& p.name () [i+1]=='A'&& p.name () [i+2] =='V'))
for (char i= 0;i<max_name_len; i++)
EEPROM.write (num_Files*max_name_len + i, entry.name () [i]);
// Serial.printin("EEPROM WRITTEN"):
num_Files++;
GET THE FIE A FRON EEISON
void get_current_File_as_fn()
for (char i=0; i< max_name_len; i++)
file_Name [i] =EEPROM.read (current_File *max_name_len + i);
Serial.println (file_Name);
OPEN THE FIle TO RUN
void sd_file_open()
get_current_File_as_fn(); //Takeout the file name from EEPROM
sd_file=SD.open (file_Name, FILE_READ) ;
// Serial.printin(sd_file);
//prant_title to_lcd();
/*//CHECK COTENT AND DISCARD IF WRONO BYTE DATA, NO ENTRY IN EEPROM*/
/*void Check_file()
while (printin . available())// read from the file untal there's nothing else in it:
buffer =sd_file.readSteingUnital('\n'): read uptil new line character meet i.e. Line by Line E ((buffer.length( )-1 !=solenoid) {
Serial.printin(This fountain can only operates 8 valves-SD Card file error:
sd file.close();
wrongbyteData=true;//Send back RETULRNING LETS EMPTY ALL THE SHIFTREGISIERS
return;}}}*/
/* DESIGH FILE STATES*/
//DIR PLAY=PLAY_ALL
//ME3_PLAY = FLAY_SINGLEmp3play()==play_Single
enum state{ PLAY_ALL, PLAY_SINGLE, PAUSED };
state current_state=PLAY_ALL;
void Play_Single()
int i;
while (sd_file.available())/// read from the file until there's nothing else in it:
buffer=sd_file.readStringUntil ('\n');
//Read uptil new line character meet i.e. Line by Line
/*if (buffer.length()-1)!= solenoid){
Serial.printin("This fountain can only operates 8 valves-sd Card File error")
sd_file.close();
//SEFORE RETURING LEIS ENTRY ALL THE SHIFTEGISTERE I
emptyshiftRegister ();
return;}
PollKeys();
PotDelay ();//This will get the PotmapValue for use in shift register
if (Nextfile==true)
Nextfile=false;
emptyShiftRegister ();
sd_file.close ();
Next_File();
return;
if (Previousfile==true)
Previousfile=false;
sd_file.close ();
Previous_File ();
//Previous File();//DO'T KOW NHY IT REQUIRED TO MAKE TWICE
return;
/*// LETS SEGEGATE THE SITES IN EACH LINE AND SEND to MICROcoTROLLES /*/
byte bytes[buffer.length()];// Store Byte data in Array of number of bytes in line
buffer.getBytes(bytes, buffer.length ()+1);
//Serial.printin(( buffer.getBytes (bytes, buffer.length()+1)) );
digitalWrite (latchPin, 0); //Lets start sending one lines byte data to Shift Register
for (int i=0;i<buffer.length();i++);
Serial.println(bytes[i],DEC);
shiftOut(dataPin, clockPin, (char)bytes[i]);
//LETS LATCHLIN "ON" ONLY WHEN THE LAST BYTE FED TO THE shiftout FUNCTION. LETS VERIFY IN FOLLONING
if (i==buffer.length ()-1);// WE KNOE THE BUFFER LENGTH HAS ONE EXTRA BYTE OF " /n" so LETS HEGATE IT
digitalWrite (latchPin, 1);
delay (PotmapValue);///Delay Based on potentiometer value
}//end of while loop
sd_file.close ();// AS file is completly read and sent to the controller so close it
if (current_state==PLAY_SINGLE)
emptyShiftRegister();
current_state== PAUSED;
}//end of function
void Play_All ()
if (sd_file)
Play_Single ();
if (current_File < (num_Files - 1))
current_File++;
sd_file_open ();
current_File =0;
sd_file_open ();
current_state==PAUSED;
void Play_Pause ()
static unsigned long last_interrupt_time = 0;
unsigned long interrupt_time =millis ();
//If interrupta come faster than 200ms, assume it's a bounce and ignoce
if (interrupt_time - last_interrupt_time > 200)
if (current_state==PLAY_ALL)
current_state=PAUSED;
current_state = PLAY_ALL;
last_interrupt_time = interrupt_time;//digitalWrite (pin, LOW);
void Next_File()
static unsigned long last_interrupt_time=0;
unsigned long interrupt_time=millis();
//If interrupta come faster than 200ms, assume it's bounce and ignore
if (interrupt_time -last_interrupt_time > 200)
sd_file.close () ;
void Previous_File ()
unsigned long interrupt_time = millis ( );
// If interrupta come faster than 200ms, assume it's a bounce and ignore
if ( interrupt_time - last_interrupt_time > 200 )
Serial.println ( " HOLLA " ) ;
sd_file.close ( ) ;
if ( current_File==0 )
current_File=num_Files - 2 ;
current_File=current_File-2 ;
current_state=PLAY_ALL ;
last_interrupt_time=interrupt_time ; // digitalWrite ( pin , LOW ) ;
void setup ()
Serial.begin (9600);
pinMode (sd_cs, OUTPUT);
// SD.begin (sd_cs);
pinMode (latchPin, OUTPUT);
//vol - mp3 vol;
//lcd.begin (50);
//lcd.print ("Barebones Mp3");
//led.display();
//Mp3.begin (mp3_cs, mp3_dcs, mp3_rst, mp3_dreq);
// Mp3. volume (vol);
lcd.begin(20, 4);
sd_card_setup();
sd_dir_setup ();
sd_file_open ();
Splash_LCD_lst();
delay (1000);
Splash_LCD_ReadFiles ();
delay (1000) ;
Splash_LCD_ReadFiles_insequence ();
delay (1000);
/*attachinterrupt (2, playpause , FALLING); attachinterrupt (0, NextSong, FALLING); attachinterrupet (1, Previousong, FALLING ); pinMode (buttonpin1. INPUT);
pinMode (buttonpin2. INPUT);
/Genotronex.begin (9600);*/
/*//HERE 15 THE TH LOOP FUNCTION /*/
void loop ()
// Serial.printin(current_state);
// Pollkeys ();
//Serial.printin(current_state );
Main_LCD ();
switch (current_state)
case PLAY_ALL:
//Pollkeya ();
Play_All();
case PLAY_SINGLE:
Play_Single ();
case PAUSED:
// Pollkeya ();
/*lup1;
menu();
lup2//*/
/*buttonstate1= digitalRead (buttonPin1);
if (buttonistat1==HIGH){
if(vol<254){
vol=vol++;}}
buttonstate2= digitalRead (buttonPin2);
if (buttonistat2==HIGH){
if(vol>0){
vol=vol--;}}*/
/*if(Genotronex.available()){
BluetoothDeta-Genotrenex.read (); if(BluetoothDate=='1'){//if number 1 predsed.. Previousong();
Genotronex.printin("Going back to the previous song.");}
if(BluntoothData=='2'){// if number 0 pressed.. playPause();
Genotronex.priatin("play/pause song.");}
if ( BluetoothData=='3' ){ // if number 0 pressed ....
NextSong ( ) ;
Genotronex.priatin ( " Going to the next song " );}
if( BluetoothData=='='){ // if number 1 pressed
if ( vol<254 ){
vol =vol +10 ;
Genotronex.priatin ( " Volume Increased " ) ;
}} If( BluetoothData=='-'){// if number 1 pressed ....
if( vol>0 ){
vol =vol -10 ;
Genotronex.priatin ( " Volume Decreased " ) ;}}} Mp3. volume ( vol);*/
/*void menu(){
Icd.setCursor (0,0); lcd.print("1.Single File"); lcd. setCursor (0, 1); lcd.print("2.All File");
lcd. setCursor (0, 2); lcd.print("3.Time delay ");
Icd. setCursor (0,3); lcd.print(" 3.Read Temp");}*/
void emptyShiftRegister ()
digitalWrite (latchPin, 0);//Lets start sending to Shift Regiater
for (int i=0;i<solenoid+1;i++)
shiftOut(dataPin, clockPin, 0x00);
// LETS LATCHPIN "ON"ONLY WHEN THE LAST BYTE FED TO THE shittout FUNCTION. LETS VERIFY IN FOLLOWING
if (i==solenoid); //WE KNOW THE BUFFER LENGTH HAS ONE EXTRA BYTE OF " /n" SO LETS NEGATE IT
delay (1000);
void shiftOut (int myDataPin, int myClockPin, byte myDataOut)
//This shifta e bite out MSS first,
//on the rising edge of the clock,
//clock idles lov /internal function setup
int i=0;
int pinState;
pinMode (myClockPin, OUTPUT);
pinMode (myDataPin, OUTPUT);
//Clear everything out juat in case to
//prepare shift regiater for bit shifting
digitalWrite (myDataPin, 0);
digitalWrite (myClockPin, 0);
//for each bit in the byte my dataout
//NOTICE THAT WE ARE COUNTINS DOWN in our for loop
//This means that %100000001 or 1" will go through such
//that it will be pin Q0 that lights.
for (i=7; i>=0; i--)
//if the value passed to myDetaout and a bitmask result
//true then. .. so if we are at i=6 and our value is
//%11010100 it would the code compares it to 0100000
// and proceeda to set pinState to 1.
if( myDataOut &(1<<i))
pinState=1;
pinState= 0;
//Seta the pln to HIGH er LOR depending an pinstate
digitalWrite (myDataPin, pinState);
//register ahifts bita on upstroke of clock pin
digitalWrite (myClockPin, 1);
//zero the data pin after shift to prevent bleed through
//stop shifting
delay (1);
/*void print title_to_lcd(){
get_title_from_id3tag ();
lcd.cleardisplay();
lcd.printin(title);
Lcd. display();}*/
///LCD STUFF
void SD_error_LCD()
lcd.setCursor (0, 4);
lcd.print ("SD Card Not Found. ..");
void Splash_LCD_lst()
lcd.clear ();
lcd.setCursor (0, 0);
lcd.print ("Graphical Waterfall");
lcd.setCursor (0, 1);
lcd.print (" By ");
lcd.print (" khalid khattak ");
lcd.setCursor (0, 3);
lcd.print (" +92-0300 7061499 ");
void Main_LCD()
lcd.clear ();
lcd.print ("File :");
lcd.setCursor (6, 0);
lcd .print (file_Name);
lcd.print ("Status:");
if (current_state==0)
lcd. setCursor (8, 1);
lcd.print ("Play All" );
else if (current_state==1)
lcd.print ("Play Single");
else if (current_state==2)
lcd.setCursor (8, 1);
lcd.print ("Pause");
//led.setCursor (0, 1);
// led.print(" By ");
// led.setCuraor (0, 2);
// led.print (" By khalid Khattak "); //Potmapvalue
lcd. setCursor (0, 3);
lcd.print ("T-Files:");
lcd.setCursor (8, 3);
lcd.print (num_Files);
lcd. setCursor (11 , 3);
lcd.print ("Time:");
lcd.setCursor (16, 3);
lcd.print (PotmapValue);
void Splash_LCD_ReadFiles()
lcd.clear ();
lcd.print ("Reading SD Card.....");
lcd.setCursor (0, 2);
lcd.print ( "Total Files : ");
lcd.setCursor (15, 2);
lcd.print ("No. of values: ");
lcd.setCursor (16 , 3);
lcd.print (solenoid*8);
void Splash_LCD_ReadFiles_insequence ()
lcd.clear ();
lcd.print (" Now Playing ");
lcd.print (" All Files");
lcd .setCursor (0, 2);
lcd.print (" in ");
lcd.print (" back to back ");
void PotDelay()
Potvalue = analogRead (PotTime);
// map it to the range of the analog out:
PotmapValue =map (Potvalue, 0, 1023, 0, 255);
// change the analog out value:
//Serial.printin (Pormapvalue);
// wait 2 milliseconds before the next loop
//for the analog-to -digital converter to settle
// Serial.println (PotmapValue);
// vait 2 milliseconda before the next loop
// tor the analog-to-digital converter to settle
// after the last reading:
delay (2);
void PollKeys()
adc_key_prev = lcd_key ; // Melihat perbedaan
lcd_key = read_LCD_buttons ();//baca tombol
if (adc_key_prev != lcd_key)
Serial.println ("Different key Selected");
switch (lcd_key)
// depending on which button was pashed, we perform an action
case btnRIGHT:
Serial.println("Right Button Preased");
/* led.clear();
tampl_waktu() ;
delay (5000);
goto lup1*/
break ;
case btnLEFT:
Previousfile =true;
//Serial.printin("Previous Button Pressed"); lcd.clear();
/*lcd.setCursor (0,0); lcd.print ("READ EEFROM ");
for (int i=0;i<256 ;i++)
detaku=eeprom_12c_read(alamat_ EEPROM, i);
delay(50)
lcd.setCursor (0,1); lcd.print ("Address: 0×" );lcd.prant(i, HEX);
lcd.setCursor(-4,2);lcd.print ("Data: 0×"); lcd.print(" dataku, HEX")
delay(1000);*/
case btnUP:
Serial.println("Up Button Pressed");/*
Icd.clear();
Lcd.print ("WRITE EERON");
for (int i=0;i<256;i++)
eeprom_i2c_write(alamat EEPROM, i,i);
delay(1000);*/
case btnDOWN:
Serial.println("Next Button Pressed");
Nextfile=true;
/*Lcd.clear();
beca_suhu( );
delay (2000); */
case btnSELECT:
Serial.println("Select Button Pressed");
/* lcd. clear();
Simpan_MMC();
delay(4000) ;*/
case btnNONE:
//go to lup1;
