Hi all!
I am making a LaserX Nerf gun, and I am having problems receiving correct IR codes. I finally got the transmitting and everything else working. I have been working on the receiver for 5 hours now and have tried 100 different things, all to no avail!
Basically, I need to receive and decode a hash to a 32 bit code. I don't need any extra info like coding type (NEC, SONY, ETC.) or anything, I just need to distinguish between different team shots.
What I'm using is:
- A DFRobot Fire-Beetle with its shield(I got it working with a Arduino Nano and the IRlib library, but need it working on this board)
- A 940nm 1.5V 100mA IR LED
- A VS1838B 3.3V / 5V 38KHz IR receiver
- Some LED indicators
- A on/off switch
- A tactile button for a trigger
- A 3.7V Li-ion battery
Schematic:
I finally got some code partially working. It reads the right code, but only once every 20 times. Here is the serial monitor output:
Code:
#include <Arduino.h>
#include <IRsend.h>
#include <IRremoteESP8266.h>
#include <IRrecv.h>
#include <IRutils.h>
const uint16_t RECV_PIN = 14; //D10:17, D12:4, D6:14
#define LED_PIN D9
#define LED_COUNT 9
#define Trigger D2
const uint16_t kIrLed = 16;//D11
IRrecv myReceiver(RECV_PIN);
IRsend irsend(kIrLed);
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
decode_results results;
static const long PURPLEir = 0x67228B44;
static const long REDir = 0xC6D404B6; //0x78653B0E;
static const long BLUEir = 0x2FFEA610;
// PURPLE
uint16_t rawDataPurple[] = {
2888, 5987, 2893,
2058, 848, 2052, 843, 2069, 795, 2104, 791, // 0, 0, 0, 0
2109, 1816, 2109, 837, 2063, 842, 2057, 848, // 1, 0, 0, 0
2052, 1873, 2055, 840, 2059, 846, 2054, 841, // 1, 0, 0, 0
2071, 794, 2106, 789, 2111, 795, 2105, 841, // 0, 0, 0, 0
1000
// RED
uint16_t rawDataRed[] = {
2899, 5977, 2897,
2065, 842, 2058, 849, 2051, 845, 2055, 842, // 0, 0, 0, 0
2058, 1869, 2056, 851, 2061, 826, 2074, 792, // 1, 0, 0, 0
2108, 789, 2111, 836, 2064, 843, 2057, 840, // 0, 0, 0, 0
2060, 846, 2054, 843, 2057, 850, 2050, 847, // 0, 0, 0, 0
1000
// BLUE
uint16_t rawDataBlue[] = {
2896, 5979, 2902,
2060, 836, 2064, 843, 2057, 848, 2052, 844, // 0, 0, 0, 0
2055, 1870, 2055, 851, 2052, 844, 2065, 820, // 1, 0, 0, 0
2080, 795, 2105, 1821, 2104, 792, 2111, 836, // 0, 1, 0, 0
2063, 843, 2057, 838, 2062, 845, 2055, 840, // 0, 0, 0, 0
1000
int life = 2;
int myColor;
int timer1;
int timer2;
int timer3;
int trig;
int teamScan = 1;
Serial.println("Setting up IR...");
myReceiver.enableIRIn(); // Start the receiver
irsend.begin();
Serial.println("Setting up trigger and LEDs...");
pinMode(Trigger, INPUT);
strip.begin();
strip.show();
strip.setBrightness(255);
trig = digitalRead(Trigger);
Serial.println("Waiting for team...");
retry:
while (digitalRead(Trigger) == LOW);
Serial.println("Trigger pressed...");
if (digitalRead(Trigger) == HIGH){
Serial.println("Trigger high...");
while (digitalRead(Trigger) == HIGH){
Serial.println(timer1);
timer1++;
delay(1);
if (timer1 == 2000){
timer1 = 0;
goto complete;
teamscan:
Serial.println("teamScan...");
if (teamScan == 4){teamScan=1;}
if (teamScan == 1){
for (int f=0;f<LED_COUNT;f++){
strip.setPixelColor(f, strip.Color(255,0,255));
strip.show();
delay(20);
myColor = 1;
else if (teamScan == 2){
strip.setPixelColor(f, strip.Color(255,0,0));
strip.show();
delay(20);
myColor = 3;
else if (teamScan == 3){
strip.setPixelColor(f, strip.Color(0,0,255));
strip.show();
delay(20);
myColor = 2;
teamScan++;
goto retry;
complete:
if (myColor == 1){
for (int k=0;k<5;k++){
strip.show();
delay(20);
delay(600);
strip.setPixelColor(f, strip.Color(0,0,0));
strip.show();
delay(20);
delay(600);
strip.show();
delay(20);
delay(3000);
for (int f=LED_COUNT;f>1;f--){
strip.show();
delay(40);
else if (myColor == 3){
strip.show();
delay(20);
delay(600);
strip.show();
delay(20);
delay(600);
strip.show();
delay(20);
delay(3000);
strip.show();
delay(40);
else if (myColor == 2){
strip.show();
delay(20);
delay(600);
strip.show();
delay(20);
delay(600);
strip.show();
delay(20);
delay(3000);
strip.show();
delay(40);
for (int f=2;f<LED_COUNT;f++){
strip.setPixelColor(f, strip.Color(0,255,0));
strip.show();
delay(20);
myReceiver.resume();
Serial.println("Trigger pulled! Shooting...");
strip.show();
shoot();
strip.show();
delay(90);
/*if (myReceiver.decode(&results)) {
//Serial.print("'real' decode: ");
Serial.println(results.value, HEX);
Serial.println("");
Serial.println(resultToTimingInfo(&results));
Serial.println("");
Serial.println("");
//Serial.print(", hash decode: ");
//Serial.println(decodeHash(&results), HEX);
code(&results);
myReceiver.resume(); // Resume decoding (necessary!)
if (myReceiver.decode(&results)){
dump(&results);
//delay(1);
void dump(decode_results *results) {
serialPrintUint64(results->value, 16);
Serial.println("");
//normal mode
if (results->value == PURPLEir && myColor == 1) {//PURPLEir
Serial.println("Purple hit!!!!");
life--;
if (life == 0){
die();
life = 2;
delay(100);
else if (results->value == BLUEir && myColor == 3) {
Serial.println("BLUE hit!!!!");
life--;
if (life == 0){
die();
life = 2;
delay(100);
else if (results->value == REDir && myColor == 2) {
Serial.println("RED hit!!!!");
life--;
if (life == 0){
die();
life = 2;
delay(100);
void die() {
rainbow(9);
void rainbow(int wait) {
// Hue of first pixel runs 5 complete loops through the color wheel.
// Color wheel has a range of 65536 but it's OK if we roll over, so
// just count from 0 to 5*65536. Adding 256 to firstPixelHue each time
// means we'll make 5*65536/256 = 1280 passes through this outer loop:
for(long firstPixelHue = 0; firstPixelHue < 5*65536; firstPixelHue += 256) {
for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
// Offset pixel hue by an amount to make one full revolution of the
// color wheel (range of 65536) along the length of the strip
// (strip.numPixels() steps):
int pixelHue = firstPixelHue + (i * 65536L / strip.numPixels());
// strip.ColorHSV() can take 1 or 3 arguments: a hue (0 to 65535) or
// optionally add saturation and value (brightness) (each 0 to 255).
// Here we're using just the single-argument hue variant. The result
// is passed through strip.gamma32() to provide 'truer' colors
// before assigning to each pixel:
strip.setPixelColor(i, strip.gamma32(strip.ColorHSV(pixelHue)));
strip.show(); // Update strip with new contents
delay(wait); // Pause for a moment
void shoot() {
//irsend.sendRaw(rawDataBlue, 36, 38);//data, 67, 38
if (myColor == 1){
irsend.sendRaw(rawDataPurple, 36, 38);//data, 67, 38
irsend.sendRaw(rawDataRed, 36, 38);//data, 67, 38
C6D404B6 is the correct code.
I really could use some help.
Thanks in advance!
