I installed Arduino 1.6.12.
I have the following Java versions installed:
~/arduino-1.6.12 $ sudo update-alternatives --config java
Es gibt 2 Auswahlmöglichkeiten für die Alternative java (welche /usr/bin/java bereitstellen).
Auswahl Pfad Priorität Status
* 0 /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java 1071 Auto-Modus
1 /usr/lib/jvm/java-6-openjdk-amd64/jre/bin/java 1061 manueller Modus
2 /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java 1071 manueller Modus
Starting ./arduino give the following error when selecting Java 7:
~/arduino-1.6.12 $ ./arduino
Picked up JAVA_TOOL_OPTIONS:
Exception in thread "main" java.lang.UnsupportedClassVersionError: processing/app/Base : Unsupported major.minor version 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:803)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:442)
at java.net.URLClassLoader.access$100(URLClassLoader.java:64)
at java.net.URLClassLoader$1.run(URLClassLoader.java:354)
at java.net.URLClassLoader$1.run(URLClassLoader.java:348)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:347)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
Starting ./arduino give the following error when selecting Java 6:
at java.lang.ClassLoader.defineClass(ClassLoader.java:648)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:277)
at java.net.URLClassLoader.access$000(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:212)
at java.net.URLClassLoader$1.run(URLClassLoader.java:206)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:325)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:296)
at java.lang.ClassLoader.loadClass(ClassLoader.java:270)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:406)
Interestingly, different code lines are mentioned, but both times version "52".
Do I need to install Java 1.5?
