wrong pulse sensor readings
the readings from the heartbeat sensor keep going to 232bpm with and without my finger
what is wrong ? :slight_smile:
#include <U8glib.h>
#define USE_ARDUINO_INTERRUPTS true
#include <PulseSensorPlayground.h>
const int PulseWire = A0;
const int LED13 = 13;
const int Threshold = 550;
const int pinSCK = 4;
const int pinMOSI = 5;
const int pinCS = 6;
const int pinDC = 7;
int bpm = 0;
PulseSensorPlayground pulseSensor;
U8GLIB_SH1106_128X64 SH1106_Display( 4, 5, 6, 7 );
void DrawHeartBeat( int pulseBPM )
  char
  szBpm[10];
  SH1106_Display.setFont ( u8g_font_courB12);
  SH1106_Display.drawStr (8, 15 , " MG-MARK-1 ");
  SH1106_Display.drawStr (3,54 , "BPM:");
  SH1106_Display.drawFrame(0, 0, 128, 64);
  SH1106_Display.drawFrame(72 ,41, 50, 16);
  sprintf( szBpm, "%d", pulseBPM );
  SH1106_Display.drawStr( 40,54, szBpm );
  SH1106_Display.drawBox( 74 ,44, 14, 10);
  SH1106_Display.drawBox( 90,44, 14, 10);
  SH1106_Display.drawBox( 106 ,44, 14, 10);
void setup(void)
  SH1106_Display.setFont(u8g_font_courB12);
  pulseSensor.analogInput(PulseWire);
  pulseSensor.blinkOnPulse(LED13);
  pulseSensor.setThreshold(Threshold);
  if (pulseSensor.begin())
    Serial.println(" pulseSensor activated ");
void loop(void)
  UpdateBPM();
  UpdateDisplay();
void UpdateBPM( void )
  static unsigned long
  timeUpdate = 0;
  unsigned long
  timeNow;
  timeNow = millis();
  if ( (timeNow - timeUpdate) < 50 )
    return;
  timeUpdate = timeNow;
  bpm = UpdateHeartRate();
  if ( bpm >= Threshold )
    digitalWrite( LED13, HIGH );
    digitalWrite( LED13, LOW );
void UpdateDisplay( void )
  timeUpdate = 0;
  unsigned long
  timeNow;
  timeNow = millis();
  if ( (timeNow - timeUpdate) < 250 )
    return;
  SH1106_Display.firstPage();
  do
    DrawHeartBeat( bpm );
    Serial.print("BPM: ");
    Serial.println( bpm );
  } while ( SH1106_Display.nextPage() );
int UpdateHeartRate( void )
  return ( pulseSensor.getBeatsPerMinute() );
delay(20
Without the SH1106 hardware and software, do you get the right results? In other words, do you have a clue where the problem is?
yep i get pretty accurate results , and if i change the threshold to a higher value the problem disappears but the sensor gets very nonsensitive
nanoR4K:
So, without some undefined hardware (display, no link) connected, using some unknown pins, your other unknown hardware (pulse sensor, no link) works.
I hope you can figure out what to do.
