Wrong sign when converting
I have a temp sensor (LM335A) connected to analog pin 0. When converting the values to degress Celsius I got wrong sign if the temperature is -0,xx. For example:
-1,xx will be displayed as -1,xx (OK) but
-0,xx will be displayed as 0,xx (wrong, missing - sign when temp is 0, something)
I have picked up the code from different examples in Arduinos examples, but because of lack of skills in this area I can't find the error in the code:
unsigned int precision =100;
unsigned int frac;
double val;
double valr;
client.print("Analog 0: ");
val = analogRead(0);
val = val - 10; // calibration of LM335
val = val * 0.48875; // 5Volt/1023 * 100
valr = val - 273.15; // convert Kelvin to Celsius
client.print(int(valr)); // prints the int part
client.print(","); // print the decimal point
if(valr >= 0)
frac = (valr - int(valr)) * precision;
frac = (int(valr)- valr ) * precision;
int frac1 = frac;
while( frac1 /= 10 )
precision /= 10;
precision /= 10;
while( precision /= 10)
client.print("0");
client.print(frac,DEC) ;
client.print(" &#176C");
client.println("
try replacing:
if(valr >= 0)
with
if(valr < 0.0){
client.print('-');
valr = -valr;
Now I got a - but missplaced .... 0,-42
Can you post a version of the code that uses Serial so I can have a look and try running it? Just replace your sensor code with a hard coded floating point value
Here it comes, you have to change the different val statement:
unsigned int frac;
double val;
double valr;
val = 567; // expected result = -0,91 (actual 0,-91)
// val = 560; // expected result = -4,33 (actual -4,-33)
// val = 618; // expected result = 24,01 (actual 24,01)
val = val * 0.48875; // 5/1023 * 100
valr = val - 273.15; // Kelvin to Celsius
Serial.print("Analog 0: ");
Serial.print(int(valr)); //prints the int part
Serial.print(","); // print the decimal point
if(valr < 0.0){
Serial.print('-');
valr = -valr;
int frac1 = frac;
precision /= 10;
precision /= 10;
Serial.print("0");
Serial.print(frac,DEC) ;
Serial.print(" &#176C");
you need to print the integer part after you print the sign. try this:
void setup(){
  unsigned int frac;
  double val;
  double valr;
  if(valr < 0.0){
    Serial.print('-');
    valr = -valr;
  int  frac1 = frac;
    precision /= 10;
  precision /= 10;
    Serial.print("0");
It works, Thank you! ;D
