Wrong values from ADC
Hi there!
I’m building a frequency meter using as input a sine wave between 0.05V-0.55V (from a peak detector) and a frequency range between 5Khz-10Khz. I tried to change the sampling rate (I need at least 20Khz) to 76Khz (setting 16 prescaler from ADCSRA register), but the resulting data from ADC it’s a constant (=255). I didn’t find anything which could cause this constant output.
Having a higher sampling rate means that I could find more precisely the max amplitudes and then I could measure the time period between two max amplitudes resulting the frequency.
Any help or tips would be much appreciated! Thanks in advance!
const int MAX_RESULTS = 256;
volatile int results [MAX_RESULTS];
volatile int resultNumber;
ADMUX = 0x20; // set A0 analog input
ADCSRA = 0xEC;// set 16 prescaler, enable ADC and interrupts and start ADC measurements
ISR (ADC_vect)
Serial.println(ADCH);
results[resultNumber++] = ADCH;
if(resultNumber == MAX_RESULTS)
ADCSRA = 0; // turn off ADC
void loop () {
while (resultNumber < MAX_RESULTS)
for (int i = 0; i < MAX_RESULTS; i++)
Serial.println (results );
  • resultNumber = 0;*
  • ADCSRA = 0xEC;*
Don’t do serial I/O in interrupt context and don’t read ADCH twice.
Fix that and get back to us.
Please remember to use code tags when posting code.
razvant19:
Hi there!
If your highest frequency is 10kHz, you do not need to sample any higher than 20kHz. Goggle “nyquist sampling theorem”
And use code tags (</>) while posting codes:
  ISR (ADC_vect)
void loop () {
  resultNumber = 0;
  ADCSRA = 0xEC;
TheMemberFormerlyKnownAsAWOL:
Don't do serial I/O in interrupt context and don't read ADCH twice.
blh64:
If your highest frequency is 10kHz, you do not need to sample any higher than 20kHz. Goggle "nyquist sampling theorem"
That's why I wrote 20Khz (having in mind the Nyquist sampling theorem)
I tried this but nothing changed.
blh64:
Theoretically, 2 times is enough; practically, it is done 5 to 10 times in some critical measurements.
razvant19:
Post your new/changed codes so that we can if you done things correctly. Why have you read only ADCH and why not both ADCL and ADCH?
razvant19:
I can’t see your code.
I can’t see your results
  ISR (ADC_vect)
void loop () {
    Serial.println (results[i]);
  resultNumber = 0;
  ADCSRA = 0xEC;
The output: Dropbox - Error
The input: Dropbox - Error
