WS1282B static colours and button press for sketch
Recently I have been playing around with my first Arduino with addressable LED Strip.
I have managed to use the FAST LED library and use the example programs on both a test strip WS1282B and then onto my install of 8 x 5m lengths of WS1282 in series. however, I have encountered some issues.
First was the Memory of the UNO couldn't handle all the strip as 60LEDS per m.
I upgraded to the MEGA and this helped for most sketches but not all as still some stability issues.
What is the next step from here? Raspberry Pi? or is there a better way.
Also, I have been searching high and low for code and tips on how to do a simple 1 colour over the entire 8x5m strips but to no avail. Any help here would be awesome!
Lastly, I'm hoping that I can use say the colour palette but include a physical button that can cycle through the different sketches if that's possible?
A small Arduino compatible processors with lots of memory and speed is the ESP32
Most libraries have a fill function to do this.
Or a simple for loop setting each LED to the same colour, three lines only.
Yes, it if you want the button to respond immediately you have to write the code as a state machine. I have posted examples of this in the past for both common libraries.
ā€œ I'm hoping that I can use say the colour palette but include a physical button that can cycle through the different sketches if that's possible?ā€
See multitasking #3:
Thanks HKJ- I will give this a go
Thanks Grumpy_Mike,
I’m new to programming so hope to work out what you mean by the for Loop, also will look back to see if I can find your past posts. Can you point me in the right direction to learn more on the for Loop stuff when using LED Strip?
Also Thanks Llaryd I will look into the multi tasking link.
You can also get at the same information through the help menu in the IDE, choose the reference option.
I am now on my laptop so I can post this now. This is for the Adafruit library. The examples that come with it are conventional blocking code, this is how I converted them into a state machine.
Look at the wipe() function for an example of setting all the LEDs to the same colour, in this case black.
// StrandTest from AdaFruit implemented as a state machine
// pattern change by push button
// By Mike Cook Jan 2016
// Fade function added Sept 2017
#define PINforControl   4 // pin connected to the small NeoPixels strip
#define NUMPIXELS1      64 // number of LEDs on strip
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMPIXELS1, PINforControl, NEO_GRB + NEO_KHZ800);
unsigned long patternInterval = 20 ; // time between steps in the pattern
unsigned long lastUpdate = 0 ; // for millis() when last update occurred
unsigned long intervals [] = { 20, 20, 50, 100, 30 } ; // speed for each pattern - add here when adding more cases
int fadeStep = 0; // state variable for fade function
int numberOfCases = 4; // how many case statements or patterns you have
const byte button = 3; // pin to connect button switch to between pin and ground
  strip.begin(); // This initialises the NeoPixel library.
  wipe(); // wipes the LED buffers
  pinMode(button, INPUT_PULLUP); // change pattern button
  static int pattern = 4, lastReading; // start with the fade function
  int reading = digitalRead(button);
  if(lastReading == HIGH && reading == LOW){
    pattern++ ; // change pattern number
    fadeStep = 0; // reset the fade state variable
    if(pattern > numberOfCases) pattern = 0; // wrap round if too big
    patternInterval = intervals[pattern]; // set speed for this pattern
    wipe(); // clear out the buffer
    delay(50); // debounce delay
  lastReading = reading; // save for next time
if(millis() - lastUpdate > patternInterval) updatePattern(pattern);
void  updatePattern(int pat){ // call the pattern currently being created
  switch(pat) {
    case 0:
        rainbow();
    case 1:
        rainbowCycle();
    case 2:
        theaterChaseRainbow();
    case 3:
         colorWipe(strip.Color(255, 0, 0)); // red
    case 4:
         fade(0,255, 0,64, 0,0, 400); // fade from black to orange and back
void fade(int redStartValue, int redEndValue, int greenStartValue, int greenEndValue, int blueStartValue, int blueEndValue, int totalSteps) {
static float redIncrement, greenIncrement, blueIncrement;
static float red, green, blue;
static boolean fadeUp = false;
if (fadeStep == 0){ // first step is to initialise the initial colour and increments
  red = redStartValue;
  green = greenStartValue;
  blue = blueStartValue;
  fadeUp = false;
  redIncrement = (float)(redEndValue - redStartValue) / (float)totalSteps;
  greenIncrement = (float)(greenEndValue - greenStartValue) / (float)totalSteps;
  blueIncrement = (float)(blueEndValue - blueStartValue) / (float)totalSteps;
  fadeStep = 1; // next time the function is called start the fade
else { // all other steps make a new colour and display it
  // make new colour
  red += redIncrement;
  green +=  greenIncrement;
  blue += blueIncrement;
  // set up the pixel buffer
  for (int i = 0; i < strip.numPixels(); i++) {
  strip.setPixelColor(i, strip.Color((int)red,(int)green,(int)blue));
 // now display it
  strip.show();
fadeStep += 1; // go on to next step
if(fadeStep >= totalSteps) { // finished fade
  if(fadeUp){ // finished fade up and back
     fadeStep = 0;
     return; // so next call re-calabrates the increments
  // now fade back
  fadeUp = true;
  redIncrement = -redIncrement;
  greenIncrement = -greenIncrement;
  blueIncrement = -blueIncrement;
  fadeStep = 1; // don't calculate the increments again but start at first change
void rainbow() { // modified from Adafruit example to make it a state machine
  static uint16_t j=0;
    for(int i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
     j++;
  if(j >= 256) j=0;
  lastUpdate = millis(); // time for next change to the display
void rainbowCycle() { // modified from Adafruit example to make it a state machine
    for(int i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
  j++;
  if(j >= 256*5) j=0;
void theaterChaseRainbow() { // modified from Adafruit example to make it a state machine
  static int j=0, q = 0;
  static boolean on = true;
     if(on){
            for (int i=0; i < strip.numPixels(); i=i+3) {
                strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      else {
               strip.setPixelColor(i+q, 0);        //turn every third pixel off
     on = !on; // toggel pixelse on or off for next time
      strip.show(); // display
      q++; // update the q variable
      if(q >=3 ){ // if it overflows reset it and update the J variable
        q=0;
        j++;
        if(j >= 256) j = 0;
void colorWipe(uint32_t c) { // modified from Adafruit example to make it a state machine
  static int i =0;
    strip.setPixelColor(i, c);
    strip.show();
  i++;
  if(i >= strip.numPixels()){
    i = 0;
    wipe(); // blank out strip
void wipe(){ // clear all LEDs
     for(int i=0;i<strip.numPixels();i++){
       strip.setPixelColor(i, strip.Color(0,0,0));
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
