i have arduino r3
and 50 x2 =100 ws 2801 led
and enigma2 solo2 receiver
i plug its and boblight plugins setup in my receiver
usb cable connect arduino (i send ledstream.pde arduino)
solo2 starting my leds is red , blue and green and very brightness
still tv picture in solo2 and tv my boblight plugin is work but my system is not perfect
because leds very low brightness
see picture http://i.hizliresim.com/eNqXYL.jpg
Hi, how are you getting power to the WS2801 light strip?
If you are using the 5V pin on the adruino uno then it will not be enough current.
If you are using a separate power supply for the strip, have you got the negative of the supply connected to the negative/gnd of the arduino?
What is the voltage needed to run the strip.
