ws2801 not working properly with FastSPI_LEDS2
I'm trying to drive a ledstrip of ws2801's, but it is not working. I've connected the strip to the Arduino's +5v and gnd, I know this doesn't deliver enough juice to drive the whole strip, but for testing I just want to light a couple up.
When I run the code listed below one led lights up, it starts out dim orange, and gets gradually brighter, after it's on full brightness nothing happens anymore. I tried switching the clk and dat pins around to no avail.
#include "FastSPI_LED2.h"
#define NUM_LEDS 150
#define DATA_PIN 11
#define CLOCK_PIN 13
CRGB leds[NUM_LEDS];
void setup () {
  delay(200);
  FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN, BGR, DATA_RATE_MHZ(1)>(leds, NUM_LEDS);
void loop () {
   // Move a single white led
   for(int whiteLed = 0; whiteLed < NUM_LEDS; whiteLed = whiteLed + 1) {
      // Turn our current led on to white, then show the leds
      leds[whiteLed] = CRGB::White;
      // Show the leds (only one of which is set to white, from above)
      FastLED.show();
      // Wait a little bit
      delay(1);
      // Turn our current led back to black for the next loop around
      leds[whiteLed] = CRGB::Black;
Never mind, apparently it matters whether you connect them backwards or not :s.
