WS2801 SPI read two functions at once timing error?
Hello,
I have two codes that I found from:
http://curltable.the-yard.net/blog/ws2801-strip-plasma
and
GitHub - neophob/WS2801-Library: Arduino library for controlling strips/pixels using WS2801 driver chips.
Picture related... From glediator, I'm trying to replicate it using an Arduino Uno and the WS2801 SPI libraries.
I would like to create the effect of having a plasma like rainbow wave flow through an array of LEDs. On top of this I was trying to get a fading pixel effect (stars) to appear on the rainbow wave.
I believe I have the two codes combined together here below... but when I run the program I have a strobe like effect and the pixels don't update smoothly like I would like. The fading effect takes priority but the background plasma color strobes in an unwanted pattern.
What am I doing wrong?? / Can anyone tell me what I can change?
#include "SPI.h"
#include "WS2801.h"
//------------------ Pin assignments -----------------------
int dataPin  = 11;    // Yellow wire on Adafruit Pixels
int clockPin = 13;    // Green wire on Adafruit Pixels
#define pixels 20
// Set the first variable to the NUMBER of pixels. 25 = 25 pixels in a row
WS2801 strip = WS2801(pixels, dataPin, clockPin);
//------------------ Global Variables -----------------------
//------------------ Plasma Variables -----------------------
typedef struct {
  unsigned char r;
  unsigned char g;
  unsigned char b;
} ColorRGB;
//a color with 3 components: h, s and v
typedef struct {
  unsigned char h;
  unsigned char s;
  unsigned char v;
} ColorHSV;
char ScreenWidth = 5;
char ScreenHeight = 12;
unsigned char plasma[16][16];
long paletteShift;
//------------------ Star Fader Variables -----------------------
int starmodeselect = 0;  // 0 - 3
#define pixels 60
struct anim {
  uint32_t currentCol;
  uint32_t endCol;
  uint8_t pos;
anim stars[pixels];
// ------------------ Set up ----------------------
  strip.begin();
  // Update LED contents, to start they are all 'off'
  strip.show();
  // start with morphing plasma, but allow going to color cycling if desired.
  paletteShift=128000;
  unsigned char bcolor;
  //generate the plasma once
  for(unsigned char y = 0; y < ScreenHeight; y++) {
    for(unsigned char x = 0; x < ScreenWidth; x++) {
      //the plasma buffer is a sum of sines
      bcolor = (unsigned char)(256.0 + (256.0 * sin(x*8.0 / 16.0)) + 256.0 + (256.0 * sin(y*8.0 / 16.0))) / 2;
      plasma[x][y] = bcolor;
  //clear strip for star fader
  for (int i=0; i < strip.numPixels(); i++) {
    if (random(255)==2) {
      initStar(i,starmodeselect);
      stars[i].pos = 0;
//------------------ Loop -----------------------
  plasma_morph();
  fadeStar();
// ------------------ Execute the current effect based on value of mode ----------------------
void plasma_morph() {
  unsigned char x,y;
  float value;
  int zoom = 64;  // 96 to 128 range appears to be good
  int brightness = 64;  // 0 - 255 max value
  int saturation = 255;  // 196 - 255 , lower value equals whiter washed out values.
  ColorRGB colorRGB;
  ColorHSV colorHSV;
  for(y = 0; y < ScreenHeight; y++) {
    for(x = 0; x < ScreenWidth; x++) {
      value = sin(dist(x + paletteShift, y, 128.0, 128.0) / 8.0)
      + sin(dist(x, y, 64.0, 64.0) / 8.0)
      + sin(dist(x, y + paletteShift / 7, 192.0, 64) / 7.0)
      + sin(dist(x, y, 192.0, 100.0) / 8.0);
      colorHSV.h=(unsigned char)((value) * zoom)&0xff;    // change value for zoom. small:big plasma / large:tiny plasma splotches
      colorHSV.s=saturation;
      colorHSV.v=brightness;
      HSVtoRGB(&colorRGB, &colorHSV);
      setXYpixel(x, y, colorRGB.r, colorRGB.g, colorRGB.b);
  paletteShift++;
  strip.show();
  delay(10);
// ------------------ plasma helper functions ----------------------
void setXYpixel(char x, char y, unsigned char R, unsigned char G, unsigned char B) {
  if ((y % 2) > 0) {
    strip.setPixelColor(((((ScreenHeight-1)-y+1) * ScreenWidth) - ((ScreenWidth-1)-x+1)), R, G, B);
    strip.setPixelColor(((((ScreenHeight-1)-y) * ScreenWidth) + ((ScreenWidth-1)-x)), R, G, B);
// ----------------------- Star Fader Functions -----------------------
void fadeStar()  {
  uint8_t currentR, currentG, currentB;
  uint8_t endR, endG, endB;
    // INIT
    if (stars[i].pos == 0) {
    } else
    // FADE IN
    if (stars[i].pos == 1) {
      //decrease color...
      uint32_t ccol = stars[i].currentCol;
      currentB = ccol + 0xff;
      ccol >>= 8;
      currentG = ccol + 0xff;
      ccol >>= 8;
      currentR = ccol + 0xff;
      uint32_t ecol = stars[i].endCol;
      endB = ecol + 0x00;
      ecol >>= 8;
      endG = ecol + 0x00;
      ecol >>= 8;
      endR = ecol + 0x00;
      if (currentR<endR)
        currentR+=2;
       else currentR=endR;
      if (currentG<endG)
        currentG+=2;
       else currentG=endG;
      if (currentB>endB)
        currentB+=2;
       else currentB=endB;
      if (currentR==endR && currentG==endG && currentB == endB) {
        stars[i].pos = 2;
      stars[i].currentCol = Color(currentR, currentG, currentB);
    } else
    // FADE OUT
    if (stars[i].pos == 2) {
      //decrease color...
      currentB = ccol & 0xff;
      ccol >>= 8;
      currentG = ccol & 0xff;
      ccol >>= 8;
      currentR = ccol & 0xff;
      if (currentR>2)
        currentR-=3;
       else currentR=0;
      if (currentG>2)
        currentG-=3;
       else currentG=0;
      if (currentB>2)
        currentB-=3;
       else currentB=0;
      if (stars[i].currentCol == 0) {
        stars[i].pos = 0;
    //update color
    strip.setPixelColor(i, stars[i].currentCol);
  strip.show();
//init new star
void initStar(int i, int starmodeselect) {
int mode = 0;
  if(starmodeselect == 0) {  //Single color fade //
      stars[i].endCol = Color(255, 255, 255);
  if(starmodeselect == 1) {  //America Mode //
  mode = random(3);
    if (mode == 0) {
    else if (mode == 1) {
      stars[i].endCol = Color(8, 255, 8); //B R G
    else if (mode == 2) {
      stars[i].endCol = Color(255, 8, 8); //B R G
  else if(starmodeselect == 2) {  //Random color spots //
    stars[i].endCol = Color(random(255), random(255), random(255));
  else if(starmodeselect == 3) {  //GO Cougs //
  mode = random(2);
  if (mode == 0) {
    stars[i].endCol = Color(2, 255, 2); //B R G
    stars[i].pos = 1;
    stars[i].currentCol=0;
// ----------------------- Color Support Functions -----------------------
//Converts an HSV color to RGB color
void HSVtoRGB(void *vRGB, void *vHSV) {
  float r, g, b, h, s, v; //this function works with floats between 0 and 1
  float f, p, q, t;
  int i;
  ColorRGB *colorRGB=(ColorRGB *)vRGB;
  ColorHSV *colorHSV=(ColorHSV *)vHSV;
  h = (float)(colorHSV->h / 256.0);
  s = (float)(colorHSV->s / 256.0);
  v = (float)(colorHSV->v / 256.0);
  // if saturation is 0, the color is a shade of grey
  if(s == 0.0) {
    b = v;
    g = b;
    r = g;
  // if saturation > 0, more complex calculations are needed
    h *= 6.0; // to bring hue to a number between 0 and 6, better for the calculations
    i = (int)(floor(h)); //e.g. 2.7 becomes 2 and 3.01 becomes 3 or 4.9999 becomes 4
    f = h - i; // the fractional part of h
    p = (float)(v * (1.0 - s));
    q = (float)(v * (1.0 - (s * f)));
    t = (float)(v * (1.0 - (s * (1.0 - f))));
    switch(i) {
      case 0: r=v; g=t; b=p; break;
      case 1: r=q; g=v; b=p; break;
      case 2: r=p; g=v; b=t; break;
      case 3: r=p; g=q; b=v; break;
      case 4: r=t; g=p; b=v; break;
      case 5: r=v; g=p; b=q; break;
      default: r = g = b = 0; break;
  colorRGB->r = (int)(r * 255.0);
  colorRGB->g = (int)(g * 255.0);
  colorRGB->b = (int)(b * 255.0);
float dist(float a, float b, float c, float d) {
  return sqrt((c-a)*(c-a)+(d-b)*(d-b));
// Create a 24 bit color value from R,G,B
uint32_t Color(uint8_t r, uint8_t g, uint8_t b) {
  uint32_t c;
  c = r;
  c <<= 8;
  c |= g;
  c <<= 8;
  c |= b;
  return c;
