My end goal is to create a countdown timer using a WS2811 led strip. For now I am trying to program for setting the desired time. What I have works, kind of. With a press of a button I am incrementing the “H” counter using H++, then sending the command to the LED strip to also increment. This works fine until I press the button 8 times. Using the LCD screen to see what the value of H is it counts …6, 7, 8, after 8 it then jumps to 255. If I remove the two lines to the LED strip the LCD screen counts up to 15 (which is my set limit) I can’t figure out why it suddenly jumps to 255 after 8 button presses. It does this with and without the WS2811 connected. Any ideas?
Arduino Uno
DFRobot LCD Keypad Shield
1 meter WS2811 LED strip
#include "FastLED.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
int keypad_pin = A0;
int keypad_value = 0;
char btn_push;
int H = 0; // count hours
#define DATA_PIN 11
#define LED_TYPE WS2811
#define COLOR_ORDER GRB
#define NUM_LEDS 10
CRGB leds[NUM_LEDS];
#define BRIGHTNESS 10
lcd.begin(16,2); //Initialize a 2x16 type LCD
lcd.clear();
FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
//FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
// set master brightness control
FastLED.setBrightness(BRIGHTNESS);
btn_push = ReadKeypad(); //reads button status
WaitBtnRelease(); //waits for the button to be released
if(btn_push == 'U' && H<15)
H++; //increment counter by one. Eighth button press causes "H" to go to -256
//H+=2; //increment counter by two. Fifth button press causes "H" to go to 255
leds[H].setRGB(255,0,0);
leds[H+1].setRGB(255,0,0);
FastLED.show();
delay(100);
lcd.setCursor(5,0);
lcd.print(H); //for debuging, prints value of "H" on LCD screen
leds[0].setRGB(255,0,0); //sets first LED to red. Clears other leds when system is reset
FastLED.show();
char ReadKeypad() //scans for button presses
/* Keypad button analog Value
no button pressed 1023
select 741
left 503
down 326
up 142
right 0
keypad_value = analogRead(keypad_pin);
if(keypad_value < 50)
return 'R';
else if(keypad_value < 150)
return 'U';
else if(keypad_value < 300)
return 'D';
else if(keypad_value < 500)
return 'L';
else if(keypad_value < 800)
return 'S';
return 'N';
void WaitBtnRelease()
while(analogRead(keypad_pin) < 800) { }
