WS2811 data corrupted at at connectors between ws2811 string light
I have ws2811 3 pin string lights that are 50 per string, controlled by arduino uno R3 and powered by 12v 300 amp. I’ve cut the string into several segments and used a 3 pin connector that is supposed to transmit ws2811 data to connect all the segments. However, when i power on the string, as soon as the data reaches a connector it doesn't transmit data properly. All the lights turn on and recieve data but do not respond to the data that should cause them to change color and blink. Anyone know what is the problem.
The pixels on ws2811 string are connected in groups by 3 leds. The string must be cut only between a complete groups - usually labelled on strip. If you cut it not on label - the resulting parts wont works properly.
Show us a diagram, because it's not clear how you have connected the segments. Also a link to the specs of the string you are using.
'Strings' and 'strips' may be different. With strings, it may be ok to cut between any LEDs.
Sorry my misunderstanding, what is the difference?
By the way, using the word "string" for a chain of leds always looks quite weird for me...
Can't say for certain because not everyone on the forum uses English as first language and may conflate strips and strings.
I have some ws2811 strings but they are 5V. I suspect the 12V variety just use higher series resistors and are therefore much less efficient. But let's see what @cytobez comes back with.
This is the LED string i'm using.
(ALITOVE 500pcs WS2811 12mm Diffused Digital Dream Color RGB LED Pixel String Light Individually Addressable LED Pixels Module for LED Screen Wall Outdoor Advertising Board Signs IP68 Waterproof DC 5V). It is a string not a strip.
Correction about voltage. I listed that the power as 12V. It's not. It is 5V. I have my sketch set to 12V. Possibly that is the problem.
I corrected the sketch to 5V. Still same issue. The description of the LED strings says this,
"Waterproof IP67 ,Each pixel can be cut off without damaging the rest pixels,can be used indoor and outdoor ,or even underwater".
This is the description of the connectors I'm am using to splice the wire back together. ( ALITOVE 20 Sets 3 Pin JST SM Male Female Plug LED Connector Cable 15cm 20awg Wire for WS2812B WS2812 WS2811 SK6812 SK6812-RGBW LED Strip Light)
Both the string lights and the connectors are using 20AWG wire
Here is a crude drawing of what I'm doing. I will have 50 of these tiles when I'm finished. I have 12 strings with 50 lights per. Each string will be cut after every 9 lights give or take one. These light segments will be placed in each tile. The connectors are needed to allow the tiles connected and disconnected as needed. This will be powered by two 300 Watt 6amp 5v transformers.
That's 30W, not 300W.
And you are now saying 5V not 12V?
That's 3.6KW. Really?
Please make sure you understand the relationship between voltage, current and power, and tell us what the specs of these power supplies and strings really are.
That tends to refer to actual 'strings'
Probably 300W not amp.
a picture may be helpful
Please post diagrams in the correct way.
You might want to look at this How to get the best out of this forum before you proceed any further.
It tells you how to post diagrams.
This is nothing to do with your secret sketch. You can't correct software for a voltage, that is a hardware problem. So please post your sketch (your program) as described in the above link.
sorry 300W is correct. but its 60 amps. I will employ two of these once all 600 LED’s are connected.
My best attempt to comply with your guidance regarding diagrams and secret sketches. I am completely ignorant to any of this stuff from voltage to sketches. Any help is appreciated.
Secret Sketch.
If i interrupt power and then repower some times no lights turn on after the first wire splice and sometimes they do but in different arrangements. The sketch (posted above) is directing the LED's to flicker on and off and change variably in color. I'm guessing that what is happening is on/off data and color data is sent once to all LED's and then not refreshed past the first splice afterwards. All LED's before the first splice operate correctly.
So how is the soldering ? Have you added any extra wire between the pixels ?
The secret sketch should just be posted here between tags, i am not downloading from somewhere.
Just make sure you specify WS2812B in the led object definition. They require longer frame reset time (300us)
Could even be a power distribution issue, could you measure the voltage at the first splice between Vcc & Gnd.
Still, my bet is poor soldering or a too long data cable. There is also a chance of just 1 broken led, but just after the splice.
Not good enough, by a long way. Are you serious about getting help?
do not use drop box post the code by copying it from the IDE, first use "select all" and then choose "copy for forum"
then go to your reply and simply use paste to post it. Is that too difficult for you?
Let me say it again
there is nothing you can do in software, which is what a sketch is called that can affect the voltage you send to a device. Even PWM needs filtering before it can send less than 5V.
My reference to secret sketch was an attempt at humor, implying it is secrete because you had not shared it with us.
Please explain, what did you corrected in the code, exactly?
/// @file    TwinkleFox.ino
/// @brief   Twinkling "holiday" lights that fade in and out.
/// @example TwinkleFox.ino
#include "FastLED.h"
#define NUM_LEDS      55
#define LED_TYPE   WS2811
#define COLOR_ORDER   GRB
#define DATA_PIN        5
//#define CLK_PIN       4
#define VOLTS          5
#define MAX_MA       4000
//  TwinkleFOX: Twinkling 'holiday' lights that fade in and out.
//  Colors are chosen from a palette; a few palettes are provided.
//  This December 2015 implementation improves on the December 2014 version
//  in several ways:
//  - smoother fading, compatible with any colors and any palettes
//  - easier control of twinkle speed and twinkle density
//  - supports an optional 'background color'
//  - takes even less RAM: zero RAM overhead per pixel
//  - illustrates a couple of interesting techniques (uh oh...)
//  The idea behind this (new) implementation is that there's one
//  basic, repeating pattern that each pixel follows like a waveform:
//  The brightness rises from 0..255 and then falls back down to 0.
//  The brightness at any given point in time can be determined as
//  as a function of time, for example:
//    brightness = sine( time ); // a sine wave of brightness over time
//  So the way this implementation works is that every pixel follows
//  the exact same wave function over time.  In this particular case,
//  I chose a sawtooth triangle wave (triwave8) rather than a sine wave,
//  but the idea is the same: brightness = triwave8( time ).
//  Of course, if all the pixels used the exact same wave form, and
//  if they all used the exact same 'clock' for their 'time base', all
//  the pixels would brighten and dim at once -- which does not look
//  like twinkling at all.
//  So to achieve random-looking twinkling, each pixel is given a
//  slightly different 'clock' signal.  Some of the clocks run faster,
//  some run slower, and each 'clock' also has a random offset from zero.
//  The net result is that the 'clocks' for all the pixels are always out
//  of sync from each other, producing a nice random distribution
//  of twinkles.
//  The 'clock speed adjustment' and 'time offset' for each pixel
//  are generated randomly.  One (normal) approach to implementing that
//  would be to randomly generate the clock parameters for each pixel
//  at startup, and store them in some arrays.  However, that consumes
//  a great deal of precious RAM, and it turns out to be totally
//  unnessary!  If the random number generate is 'seeded' with the
//  same starting value every time, it will generate the same sequence
//  of values every time.  So the clock adjustment parameters for each
//  pixel are 'stored' in a pseudo-random number generator!  The PRNG
//  is reset, and then the first numbers out of it are the clock
//  adjustment parameters for the first pixel, the second numbers out
//  of it are the parameters for the second pixel, and so on.
//  In this way, we can 'store' a stable sequence of thousands of
//  random clock adjustment parameters in literally two bytes of RAM.
//  There's a little bit of fixed-point math involved in applying the
//  clock speed adjustments, which are expressed in eighths.  Each pixel's
//  clock speed ranges from 8/8ths of the system clock (i.e. 1x) to
//  23/8ths of the system clock (i.e. nearly 3x).
//  On a basic Arduino Uno or Leonardo, this code can twinkle 300+ pixels
//  smoothly at over 50 updates per seond.
//  -Mark Kriegsman, December 2015
CRGBArray<NUM_LEDS> leds;
// Overall twinkle speed.
// 0 (VERY slow) to 8 (VERY fast).
// 4, 5, and 6 are recommended, default is 4.
#define TWINKLE_SPEED 4
// Overall twinkle density.
// 0 (NONE lit) to 8 (ALL lit at once).
// Default is 5.
#define TWINKLE_DENSITY 5
// How often to change color palettes.
#define SECONDS_PER_PALETTE  30
// Also: toward the bottom of the file is an array
// called "ActivePaletteList" which controls which color
// palettes are used; you can add or remove color palettes
// from there freely.
// Background color for 'unlit' pixels
// Can be set to CRGB::Black if desired.
CRGB gBackgroundColor = CRGB::Black;
// Example of dim incandescent fairy light background color
// CRGB gBackgroundColor = CRGB(CRGB::FairyLight).nscale8_video(16);
// If AUTO_SELECT_BACKGROUND_COLOR is set to 1,
// then for any palette where the first two entries
// are the same, a dimmed version of that color will
// automatically be used as the background color.
#define AUTO_SELECT_BACKGROUND_COLOR 0
// If COOL_LIKE_INCANDESCENT is set to 1, colors will
// fade out slighted 'reddened', similar to how
// incandescent bulbs change color as they get dim down.
#define COOL_LIKE_INCANDESCENT 1
CRGBPalette16 gCurrentPalette;
CRGBPalette16 gTargetPalette;
  delay( 3000 ); //safety startup delay
  FastLED.setMaxPowerInVoltsAndMilliamps( VOLTS, MAX_MA);
  FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS)
    .setCorrection(TypicalLEDStrip);
  chooseNextColorPalette(gTargetPalette);
  EVERY_N_SECONDS( SECONDS_PER_PALETTE ) {
    chooseNextColorPalette( gTargetPalette );
  EVERY_N_MILLISECONDS( 10 ) {
    nblendPaletteTowardPalette( gCurrentPalette, gTargetPalette, 12);
  drawTwinkles( leds);
  FastLED.show();
//  This function loops over each pixel, calculates the
//  adjusted 'clock' that this pixel should use, and calls
//  "CalculateOneTwinkle" on each pixel.  It then displays
//  either the twinkle color of the background color,
//  whichever is brighter.
void drawTwinkles( CRGBSet& L)
  // "PRNG16" is the pseudorandom number generator
  // It MUST be reset to the same starting value each time
  // this function is called, so that the sequence of 'random'
  // numbers that it generates is (paradoxically) stable.
  uint16_t PRNG16 = 11337;
  uint32_t clock32 = millis();
  // Set up the background color, "bg".
  // if AUTO_SELECT_BACKGROUND_COLOR == 1, and the first two colors of
  // the current palette are identical, then a deeply faded version of
  // that color is used for the background color
  CRGB bg;
  if( (AUTO_SELECT_BACKGROUND_COLOR == 1) &&
      (gCurrentPalette[0] == gCurrentPalette[1] )) {
    bg = gCurrentPalette[0];
    uint8_t bglight = bg.getAverageLight();
    if( bglight > 64) {
      bg.nscale8_video( 16); // very bright, so scale to 1/16th
    } else if( bglight > 16) {
      bg.nscale8_video( 64); // not that bright, so scale to 1/4th
      bg.nscale8_video( 86); // dim, scale to 1/3rd.
    bg = gBackgroundColor; // just use the explicitly defined background color
  uint8_t backgroundBrightness = bg.getAverageLight();
  for( CRGB& pixel: L) {
    PRNG16 = (uint16_t)(PRNG16 * 2053) + 1384; // next 'random' number
    uint16_t myclockoffset16= PRNG16; // use that number as clock offset
    // use that number as clock speed adjustment factor (in 8ths, from 8/8ths to 23/8ths)
    uint8_t myspeedmultiplierQ5_3 =  ((((PRNG16 & 0xFF)>>4) + (PRNG16 & 0x0F)) & 0x0F) + 0x08;
    uint32_t myclock30 = (uint32_t)((clock32 * myspeedmultiplierQ5_3) >> 3) + myclockoffset16;
    uint8_t  myunique8 = PRNG16 >> 8; // get 'salt' value for this pixel
    // We now have the adjusted 'clock' for this pixel, now we call
    // the function that computes what color the pixel should be based
    // on the "brightness = f( time )" idea.
    CRGB c = computeOneTwinkle( myclock30, myunique8);
    uint8_t cbright = c.getAverageLight();
    int16_t deltabright = cbright - backgroundBrightness;
    if( deltabright >= 32 || (!bg)) {
      // If the new pixel is significantly brighter than the background color,
      // use the new color.
      pixel = c;
    } else if( deltabright > 0 ) {
      // If the new pixel is just slightly brighter than the background color,
      // mix a blend of the new color and the background color
      pixel = blend( bg, c, deltabright * 8);
      // if the new pixel is not at all brighter than the background color,
      // just use the background color.
      pixel = bg;
//  This function takes a time in pseudo-milliseconds,
//  figures out brightness = f( time ), and also hue = f( time )
//  The 'low digits' of the millisecond time are used as
//  input to the brightness wave function.
//  The 'high digits' are used to select a color, so that the color
//  does not change over the course of the fade-in, fade-out
//  of one cycle of the brightness wave function.
//  The 'high digits' are also used to determine whether this pixel
//  should light at all during this cycle, based on the TWINKLE_DENSITY.
CRGB computeOneTwinkle( uint32_t ms, uint8_t salt)
  uint16_t ticks = ms >> (8-TWINKLE_SPEED);
  uint8_t fastcycle8 = ticks;
  uint16_t slowcycle16 = (ticks >> 8) + salt;
  slowcycle16 += sin8( slowcycle16);
  slowcycle16 =  (slowcycle16 * 2053) + 1384;
  uint8_t slowcycle8 = (slowcycle16 & 0xFF) + (slowcycle16 >> 8);
  uint8_t bright = 0;
  if( ((slowcycle8 & 0x0E)/2) < TWINKLE_DENSITY) {
    bright = attackDecayWave8( fastcycle8);
  uint8_t hue = slowcycle8 - salt;
  CRGB c;
  if( bright > 0) {
    c = ColorFromPalette( gCurrentPalette, hue, bright, NOBLEND);
    if( COOL_LIKE_INCANDESCENT == 1 ) {
      coolLikeIncandescent( c, fastcycle8);
    c = CRGB::Black;
  return c;
// This function is like 'triwave8', which produces a
// symmetrical up-and-down triangle sawtooth waveform, except that this
// function produces a triangle wave with a faster attack and a slower decay:
uint8_t attackDecayWave8( uint8_t i)
  if( i < 86) {
    return i * 3;
    i -= 86;
    return 255 - (i + (i/2));
// This function takes a pixel, and if its in the 'fading down'
// part of the cycle, it adjusts the color a little bit like the
// way that incandescent bulbs fade toward 'red' as they dim.
void coolLikeIncandescent( CRGB& c, uint8_t phase)
  if( phase < 128) return;
  uint8_t cooling = (phase - 128) >> 4;
  c.g = qsub8( c.g, cooling);
  c.b = qsub8( c.b, cooling * 2);
// A mostly red palette with green accents and white trim.
// "CRGB::Gray" is used as white to keep the brightness more uniform.
const TProgmemRGBPalette16 RedGreenWhite_p FL_PROGMEM =
{  CRGB::Red, CRGB::Red, CRGB::Red, CRGB::Red,
   CRGB::Red, CRGB::Red, CRGB::Gray, CRGB::Gray,
   CRGB::Green, CRGB::Green, CRGB::Green, CRGB::Green };
// A mostly (dark) green palette with red berries.
#define Holly_Green 0x00580c
#define Holly_Red   0xB00402
const TProgmemRGBPalette16 Holly_p FL_PROGMEM =
{  Holly_Green, Holly_Green, Holly_Green, Holly_Green,
   Holly_Green, Holly_Green, Holly_Green, Holly_Red
// A red and white striped palette
const TProgmemRGBPalette16 RedWhite_p FL_PROGMEM =
   CRGB::Gray, CRGB::Gray, CRGB::Gray, CRGB::Gray,
   CRGB::Gray, CRGB::Gray, CRGB::Gray, CRGB::Gray };
// A mostly blue palette with white accents.
const TProgmemRGBPalette16 BlueWhite_p FL_PROGMEM =
{  CRGB::Blue, CRGB::Blue, CRGB::Blue, CRGB::Blue,
   CRGB::Blue, CRGB::Gray, CRGB::Gray, CRGB::Gray };
// A pure "fairy light" palette with some brightness variations
#define HALFFAIRY ((CRGB::FairyLight & 0xFEFEFE) / 2)
#define QUARTERFAIRY ((CRGB::FairyLight & 0xFCFCFC) / 4)
const TProgmemRGBPalette16 FairyLight_p FL_PROGMEM =
{  CRGB::FairyLight, CRGB::FairyLight, CRGB::FairyLight, CRGB::FairyLight,
   HALFFAIRY,        HALFFAIRY,        CRGB::FairyLight, CRGB::FairyLight,
   QUARTERFAIRY,     QUARTERFAIRY,     CRGB::FairyLight, CRGB::FairyLight,
   CRGB::FairyLight, CRGB::FairyLight, CRGB::FairyLight, CRGB::FairyLight };
// A palette of soft snowflakes with the occasional bright one
const TProgmemRGBPalette16 Snow_p FL_PROGMEM =
{  0x304048, 0x304048, 0x304048, 0x304048,
   0x304048, 0x304048, 0x304048, 0xE0F0FF };
// A palette reminiscent of large 'old-school' C9-size tree lights
// in the five classic colors: red, orange, green, blue, and white.
#define C9_Red    0xB80400
#define C9_Orange 0x902C02
#define C9_Green  0x046002
#define C9_Blue   0x070758
#define C9_White  0x606820
const TProgmemRGBPalette16 RetroC9_p FL_PROGMEM =
{  C9_Red,    C9_Orange, C9_Red,    C9_Orange,
   C9_Orange, C9_Red,    C9_Orange, C9_Red,
   C9_Green,  C9_Green,  C9_Green,  C9_Green,
   C9_Blue,   C9_Blue,   C9_Blue,
   C9_White
// A cold, icy pale blue palette
#define Ice_Blue1 0x0C1040
#define Ice_Blue2 0x182080
#define Ice_Blue3 0x5080C0
const TProgmemRGBPalette16 Ice_p FL_PROGMEM =
  Ice_Blue1, Ice_Blue1, Ice_Blue1, Ice_Blue1,
  Ice_Blue2, Ice_Blue2, Ice_Blue2, Ice_Blue3
// Add or remove palette names from this list to control which color
// palettes are used, and in what order.
const TProgmemRGBPalette16* ActivePaletteList[] = {
  &RetroC9_p,
  &BlueWhite_p,
  &RainbowColors_p,
  &FairyLight_p,
  &RedGreenWhite_p,
  &PartyColors_p,
  &RedWhite_p,
  &Snow_p,
  &Holly_p,
  &Ice_p
// Advance to the next color palette in the list (above).
void chooseNextColorPalette( CRGBPalette16& pal)
  const uint8_t numberOfPalettes = sizeof(ActivePaletteList) / sizeof(ActivePaletteList[0]);
  static uint8_t whichPalette = -1;
  whichPalette = addmod8( whichPalette, 1, numberOfPalettes);
  pal = *(ActivePaletteList[whichPalette]);
#define VOLTS 5
