Hi there,
i have been working on this project for 2 full days now to get the understanding on what i can do with the ws2812 led strip. I am now stumbling on a problem i cannot figure out (lack of knowlegde).
This is what i want to accomplish:
I want for now to use two ws2812 ledstrips on two different ports of the arduino. Both doing a TheatreChase. Ledstrip A starts TheatrChase when i press a button (pressing the button just once starts the whole process...with the code i have now i must press the button after every Pattern). After about 4 seconds i want strip B to also start the TheatreChase. Strip A must do the TheatreChase continousely while Strip B needs to do the TheatreChase on the led's 0 till led 16. After 5 seconds it must turn on led 11 till 20 (while led 0-16 still does the TheatreChase) for about 3 seconds and turn it of again, then switch led 21 till 25 for about 5 seconds (while led 0-16 still does the TheatreChase) and then switch it off...
I hope this makes it clear on what i want to accive....My english is not perfect (i am Dutch)
I have been trying so many different things in the code, that i lost track of what i did and what i did not try...
I hope you can help me get this code finished....Here is what i have done till now....
int buttonPin = 0; // De knop zit op pin 0
int oldButtonVal = 0;
#define LEDCOUNT 50 // aantal LEDs in de strip
#define PINA 6 // pin nummer waar strip A data op zit
#define PINB 5 // pin nummer waar strip B data op zit
#define TPIXELA 29 //aantal leds op strip A
#define TPIXELB 16 //aantal leds op strip B
// DEFINITIES
// Parameter 3 = RGB LED vlaggen, combineer indien nodig:
// NEO_KHZ800 800 KHz bitstream (de meeste NeoPixel producten met WS2812 LEDs)
// NEO_KHZ400 400 KHz (klassieke 'v1' (niet v2) FLORA pixels, WS2811 drivers)
// NEO_GRB RGB LED volgens GRB bitstream (de meeste NeoPixel produkten)
// NEO_RGB RGB LED volgens RGB bitstream (v1 FLORA pixels, niet v2)
Adafruit_NeoPixel strip_a = Adafruit_NeoPixel(TPIXELA, PINA, NEO_RGB + NEO_KHZ800);
Adafruit_NeoPixel strip_b = Adafruit_NeoPixel(TPIXELB, PINB, NEO_RGB + NEO_KHZ800);
int nPatterns = 4;
int lightPattern = 1;
// begin/initialisatie bij drukken knop of reset knop:
strip_a.begin();
strip_a.show(); // initialisatie van alle LEDs op strip A (resulteert in UIT zetten hier)
strip_b.begin();
strip_b.show(); // initialisatie van alle LEDs op strip B (resulteert in UIT zetten hier)
pinMode(buttonPin, INPUT); // initializeer de knop als input
digitalWrite(buttonPin, HIGH); // knop pin is HIGH, dus het veranderd naar 0 bij ingedrukt.
// Pattern 1 - White light, all LEDs in the strip are white
void pattern1() {
// Zogenaamde theater chase voorbeeld ...
theaterChase(strip_a.Color(255, 0, 0), 125);
} // Rood, parameter 1 = Kleurcode 255,0,0 Parameter 2 = snelheid van het looplicht
//Theatre-style kruipende LEDs.
void theaterChase(uint32_t c, uint8_t wait) {
for (int q=0; q < 3; q++) {
for (int i=0; i < strip_a.numPixels(); i=i+3) {
strip_a.setPixelColor(i+q, c);
} //zet elke 3de RGD LED aan
strip_a.setBrightness(75);
strip_a.show();
delay(200); // tijd dat de led aan blijft en daarna door onderstaande code wordt uitgeschakeld
strip_a.setPixelColor(i+q, 0); //zet elke 3de RGB LED uit
strip_a.Color(0, 0, 0);
strip_a.show();
// Pattern 2 - Red light, all LEDs in the strip are red
void pattern2() {
theaterChase1(strip_b.Color(255, 150, 0), 125);
void theaterChase1(uint32_t c, uint8_t wait) {
for (int i=0; i < strip_b.numPixels(); i=i+3) {
strip_b.setPixelColor(i+q, c);
strip_b.setPixelColor(0, strip_b.Color(0, 255, 0)); // Red
strip_b.setPixelColor(10, strip_b.Color(0, 255, 0));
strip_b.setPixelColor(12, strip_b.Color(0, 255, 0));
strip_b.setPixelColor(13, strip_b.Color(0, 255, 0));
strip_b.setPixelColor(14, strip_b.Color(0, 255, 0));
strip_b.setBrightness(75);
strip_b.show();
strip_b.setPixelColor(i+q, 0); //zet elke 3de RGB LED uit
// Pattern 3 - Orange light, all LEDs in the strip are orange
void pattern3() {
strip_b.setPixelColor(0, strip_b.Color(255, 128, 0)); // Orange
strip_b.setPixelColor(1, strip_b.Color(255, 128, 0));
strip_b.setPixelColor(2, strip_b.Color(255, 128, 0));
strip_b.setPixelColor(3, strip_b.Color(255, 128, 0));
strip_b.setPixelColor(4, strip_b.Color(255, 128, 0));
strip_b.show();
// Pattern 4 - Yellow light, all LEDs in the strip are yellow
void pattern4() {
strip_a.setPixelColor(0, strip_a.Color(255, 255, 0)); // Yellow
strip_a.setPixelColor(1, strip_a.Color(255, 255, 0));
strip_a.setPixelColor(2, strip_a.Color(255, 255, 0));
strip_a.setPixelColor(3, strip_a.Color(255, 255, 0));
strip_a.setPixelColor(4, strip_a.Color(255, 255, 0));
strip_a.show();
// the loop routine runs over and over again forever;
// read that state of the pushbutton value;
int buttonVal = digitalRead(buttonPin);
if (buttonVal == LOW && oldButtonVal == HIGH) {// button has just been pressed
lightPattern = lightPattern + 1;
if (lightPattern > nPatterns) lightPattern = 1;
oldButtonVal = buttonVal;
switch(lightPattern) {
case 1:
pattern1();
case 2:
pattern2();
case 3:
pattern3();
case 4:
pattern4();
