WS2812B and neopixel library
i just purchased a WS2812B string. seems different than what is shown on the tutorials. it looks like it has ground, power and just one data connection in the middle. the tutorials i found are showing the fast led library. I would really really prefer to use the neopixel library. is this string compatable with the neopixel library?
can someone give me the line with the setup parameters for my sketch?
i can take it from there!
Is it too much to ask which string?
Yes your strip is compatible of course. Connect sufficient power (either 5v or 12v depending on the strip) and use common Ground (to the Arduino). Connect the data pin to the Arduino via a 470R resistor. The neopixel library comes with examples in the IDE go to File->Examples->Adafruit Neopixel and select one like FI strandtest
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel.  Avoid connecting
// on a live circuit...if you must, connect GND first.
