Hi i'm a newbie here wondered if anyone shed light and point me in the right direction as to what i need to do ,
the project i have works fine and consists of 2 ws2812 light strips,1 servo,1 lcd display, 2 relays and a sound chip the goal was to include this in a Droid i'm currently building
so far 1 light works with the sound chip for the weapon , the second is for the eye light
the sounds the sounds are stored as numbers so i can call a number to play and also be able to play the next sound by just adding 1 each time i press button
however i'm now wanting to be able to change the colour of the one strip i use for eye in a similar approach to the weapon sounds. how do i make the html colours into a table of numbers selectable that changes. as at the moment i only have #define EyeColour Red
if i want to change it to e.g blue i have to change the EyeColour variable
what i want is to be able to call a number for e.g 1 (SelectEyeColour) and be able increment the number which changes to one stored in a table so each time i press a select button
i.e
1=red , 2=blue , 3=green , 4=white etc... so when i call "EyeColour" i can select the next colour by just adding 1
LionSri:
As groundFungus said, you might just need an array.
Sometimes it is useful to have a ‘palette’ of colours so you can pick a colour with a single number (the palette index).
I have attached a header file which creates arrays for a palette I use.
You can see the colours in this palette by looking at colour_palette.html
You can then more easily use the colours like:
#include <palette.h>
// Use an array for a particular sequence of colours to step thru:
byte StepColours[5]= { WHITE, RED, GREEN, YELLOW, BLUE };
// 'colour' is a number 0 to 255 which picks a colour from the palette
// - get the separate r,g,b values like this:
colour= StepColours[2]; // step to colour '2'
red= pgm_read_byte_near(pal_red + colour);
green= pgm_read_byte_near(pal_green + colour);
blue= pgm_read_byte_near(pal_blue + colour);
You can also step thru the whole palette from colour 0 to colour 239 to get a rainbow colour effect.
[quote author=TonyWilk link=msg=3591743 date=1517663143]
Sometimes it is useful to have a 'palette' of colours so you can pick a colour with a single number (the palette index).
Thanks Tony , that is just perfect for what i'm looking for
