Sorry, is my first topic, so i will try to figure it out.
So this is the code:
Nothing happens in a vacuum. Thanks to the following:
Adafruit
https://learn.adafruit.com/adafruit-neopixel-uberguide
Indrek Luuk - Circuit Journal
circuitjournal.com/how-to-use-the-dfplayer-mini-mp3-module-with-an-arduino
One Guy, One Blog
oneguyoneblog.com/2017/11/01/lightning-thunder-arduino-halloween-diy/
"If I have seen further it is by standing on the shoulders of Giants."
- Isaac Newton
// these libraries must be installed prior to uploading
// includes
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
#ifdef __AVR__
#include <avr/power.h>
#endif
// set number of pixels in strip
int numPix = 16;
// set pin to control neopixels
int neoPin = 4;
// set initial brightness 0-255
int brightness = 255;
// create led object
Adafruit_NeoPixel ledStrip = Adafruit_NeoPixel(numPix, neoPin, NEO_GRBW + NEO_KHZ800);
// assign pins to TX and RX for player
static const uint8_t PIN_MP3_TX = 2;
static const uint8_t PIN_MP3_RX = 3;
SoftwareSerial softwareSerial(PIN_MP3_RX, PIN_MP3_TX);
// create the player object
DFRobotDFPlayerMini myPlayer;
// initialize neopixels
ledStrip.begin();
ledStrip.setBrightness(brightness);
ledStrip.show();
// initialize serial port for output
// initialize player serial port
softwareSerial.begin(9600);
// connect to player - print result
if (myPlayer.begin(softwareSerial)) {
Serial.println("Connection successful.");
// set initial volume 0-30
myPlayer.volume(30);
Serial.println("Connection failed.");
// volume defines both the led brightness and delay after flash
int volMin = 15;
int volMax = 31;
int randomVol = random(volMin, volMax);
// upper value should be one more than total tracks
int randomTrack = random(1, 9);
// lightning variables
// use rgbw neopixel adjust the following values to tweak lightning base color
int r = random(40, 80);
int g = random(10, 25);
int b = random(0, 10);
// return 32 bit color
uint32_t color = ledStrip.Color(r, g, b, 50);
// number of flashes
int flashCount = random (5, 15);
// flash white brightness range - 0-255
int flashBrightnessMin = 10;
int flashBrightnessMax = 255;
// flash duration range - ms
int flashDurationMin = 5;
int flashDurationMax = 75;
// flash off range - ms
int flashOffsetMin = 0;
int flashOffsetMax = 75;
// time to next flash range - ms
int nextFlashDelayMin = 1;
int nextFlashDelayMax = 50;
// map white value to volume - louder is brighter
int flashBrightness = map(randomVol, volMin, volMax, flashBrightnessMin, flashBrightnessMax);
// map flash to thunder delay - invert mapping
int thunderDelay = map(randomVol, volMin, volMax, 1000, 250);
// randomize pause between strikes
// longests track length - ms
int longestTrack = 18000;
// intensity - closer to longestTrack is more intense
int stormIntensity = 30000;
long strikeDelay = random(longestTrack, stormIntensity);
// debug serial print
Serial.println("FLASH");
Serial.print("Track: ");
Serial.println(randomTrack);
Serial.print("Volume: ");
Serial.println(randomVol);
Serial.print("Brightness: ");
Serial.println(flashBrightness);
Serial.print("Thunder delay: ");
Serial.println(thunderDelay);
Serial.print("Strike delay: ");
Serial.println(strikeDelay);
Serial.print("-");
for (int flash = 0 ; flash <= flashCount; flash += 1) {
// add variety to color
int colorV = random(0, 50);
if (colorV < 0) colorV = 0;
// flash segments of neopixel strip
color = ledStrip.Color(r + colorV, g + colorV, b + colorV, flashBrightness);
ledStrip.fill(color, 0, 4);
ledStrip.show();
delay(random(flashOffsetMin, flashOffsetMax));
ledStrip.fill(color, 8, 4);
ledStrip.show();
ledStrip.fill(color, 4, 4);
ledStrip.show();
ledStrip.fill(color, 9, 14);
ledStrip.show();
delay (random(flashDurationMin, flashDurationMax));
ledStrip.clear();
ledStrip.show();
delay (random(nextFlashDelayMin, nextFlashDelayMax));
// pause between flash and thunder
delay (thunderDelay);
// trigger audio - randomize volume and track
myPlayer.volume(randomVol);
myPlayer.play(randomTrack);
delay(strikeDelay);
The Library is Adafruit_NeoPixel and the .h file has, this code:
* @file Adafruit_NeoPixel.h
* This is part of Adafruit's NeoPixel library for the Arduino platform,
* allowing a broad range of microcontroller boards (most AVR boards,
* many ARM devices, ESP8266 and ESP32, among others) to control Adafruit
* NeoPixels, FLORA RGB Smart Pixels and compatible devices -- WS2811,
* WS2812, WS2812B, SK6812, etc.
* Adafruit invests time and resources providing this open source code,
* please support Adafruit and open-source hardware by purchasing products
* from Adafruit!
* Written by Phil "Paint Your Dragon" Burgess for Adafruit Industries,
* with contributions by PJRC, Michael Miller and other members of the
* open source community.
* This file is part of the Adafruit_NeoPixel library.
* Adafruit_NeoPixel is free software: you can redistribute it and/or
* modify it under the terms of the GNU Lesser General Public License as
* published by the Free Software Foundation, either version 3 of the
* License, or (at your option) any later version.
* Adafruit_NeoPixel is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public
* License along with NeoPixel. If not, see
* <http://www.gnu.org/licenses/>.
#ifndef ADAFRUIT_NEOPIXEL_H
#define ADAFRUIT_NEOPIXEL_H
#ifdef ARDUINO
#if (ARDUINO >= 100)
#include <Arduino.h>
#else
#include <WProgram.h>
#include <pins_arduino.h>
#endif
#endif
#ifdef TARGET_LPC1768
#endif
// The order of primary colors in the NeoPixel data stream can vary among
// device types, manufacturers and even different revisions of the same
// item. The third parameter to the Adafruit_NeoPixel constructor encodes
// the per-pixel byte offsets of the red, green and blue primaries (plus
// white, if present) in the data stream -- the following #defines provide
// an easier-to-use named version for each permutation. e.g. NEO_GRB
// indicates a NeoPixel-compatible device expecting three bytes per pixel,
// with the first byte transmitted containing the green value, second
// containing red and third containing blue. The in-memory representation
// of a chain of NeoPixels is the same as the data-stream order; no
// re-ordering of bytes is required when issuing data to the chain.
// Most of these values won't exist in real-world devices, but it's done
// this way so we're ready for it (also, if using the WS2811 driver IC,
// one might have their pixels set up in any weird permutation).
// Bits 5,4 of this value are the offset (0-3) from the first byte of a
// pixel to the location of the red color byte. Bits 3,2 are the green
// offset and 1,0 are the blue offset. If it is an RGBW-type device
// (supporting a white primary in addition to R,G,B), bits 7,6 are the
// offset to the white byte...otherwise, bits 7,6 are set to the same value
// as 5,4 (red) to indicate an RGB (not RGBW) device.
// i.e. binary representation:
// 0bWWRRGGBB for RGBW devices
// 0bRRRRGGBB for RGB
// RGB NeoPixel permutations; white and red offsets are always same
// Offset: W R G B
#define NEO_RGB ((0<<6) | (0<<4) | (1<<2) | (2)) ///< Transmit as R,G,B
#define NEO_RBG ((0<<6) | (0<<4) | (2<<2) | (1)) ///< Transmit as R,B,G
#define NEO_GRB ((1<<6) | (1<<4) | (0<<2) | (2)) ///< Transmit as G,R,B
#define NEO_GBR ((2<<6) | (2<<4) | (0<<2) | (1)) ///< Transmit as G,B,R
#define NEO_BRG ((1<<6) | (1<<4) | (2<<2) | (0)) ///< Transmit as B,R,G
#define NEO_BGR ((2<<6) | (2<<4) | (1<<2) | (0)) ///< Transmit as B,G,R
// RGBW NeoPixel permutations; all 4 offsets are distinct
// Offset: W R G B
#define NEO_WRGB ((0<<6) | (1<<4) | (2<<2) | (3)) ///< Transmit as W,R,G,B
#define NEO_WRBG ((0<<6) | (1<<4) | (3<<2) | (2)) ///< Transmit as W,R,B,G
#define NEO_WGRB ((0<<6) | (2<<4) | (1<<2) | (3)) ///< Transmit as W,G,R,B
#define NEO_WGBR ((0<<6) | (3<<4) | (1<<2) | (2)) ///< Transmit as W,G,B,R
#define NEO_WBRG ((0<<6) | (2<<4) | (3<<2) | (1)) ///< Transmit as W,B,R,G
#define NEO_WBGR ((0<<6) | (3<<4) | (2<<2) | (1)) ///< Transmit as W,B,G,R
#define NEO_RWGB ((1<<6) | (0<<4) | (2<<2) | (3)) ///< Transmit as R,W,G,B
#define NEO_RWBG ((1<<6) | (0<<4) | (3<<2) | (2)) ///< Transmit as R,W,B,G
#define NEO_RGWB ((2<<6) | (0<<4) | (1<<2) | (3)) ///< Transmit as R,G,W,B
#define NEO_RGBW ((3<<6) | (0<<4) | (1<<2) | (2)) ///< Transmit as R,G,B,W
#define NEO_RBWG ((2<<6) | (0<<4) | (3<<2) | (1)) ///< Transmit as R,B,W,G
#define NEO_RBGW ((3<<6) | (0<<4) | (2<<2) | (1)) ///< Transmit as R,B,G,W
#define NEO_GWRB ((1<<6) | (2<<4) | (0<<2) | (3)) ///< Transmit as G,W,R,B
#define NEO_GWBR ((1<<6) | (3<<4) | (0<<2) | (2)) ///< Transmit as G,W,B,R
#define NEO_GRWB ((2<<6) | (1<<4) | (0<<2) | (3)) ///< Transmit as G,R,W,B
#define NEO_GRBW ((3<<6) | (1<<4) | (0<<2) | (2)) ///< Transmit as G,R,B,W
#define NEO_GBWR ((2<<6) | (3<<4) | (0<<2) | (1)) ///< Transmit as G,B,W,R
#define NEO_GBRW ((3<<6) | (2<<4) | (0<<2) | (1)) ///< Transmit as G,B,R,W
#define NEO_BWRG ((1<<6) | (2<<4) | (3<<2) | (0)) ///< Transmit as B,W,R,G
#define NEO_BWGR ((1<<6) | (3<<4) | (2<<2) | (0)) ///< Transmit as B,W,G,R
#define NEO_BRWG ((2<<6) | (1<<4) | (3<<2) | (0)) ///< Transmit as B,R,W,G
#define NEO_BRGW ((3<<6) | (1<<4) | (2<<2) | (0)) ///< Transmit as B,R,G,W
#define NEO_BGWR ((2<<6) | (3<<4) | (1<<2) | (0)) ///< Transmit as B,G,W,R
#define NEO_BGRW ((3<<6) | (2<<4) | (1<<2) | (0)) ///< Transmit as B,G,R,W
// Add NEO_KHZ400 to the color order value to indicate a 400 KHz device.
// All but the earliest v1 NeoPixels expect an 800 KHz data stream, this is
// the default if unspecified. Because flash space is very limited on ATtiny
// devices (e.g. Trinket, Gemma), v1 NeoPixels aren't handled by default on
// those chips, though it can be enabled by removing the ifndef/endif below,
// but code will be bigger. Conversely, can disable the NEO_KHZ400 line on
// other MCUs to remove v1 support and save a little space.
#define NEO_KHZ800 0x0000 ///< 800 KHz data transmission
#ifndef __AVR_ATtiny85__
#define NEO_KHZ400 0x0100 ///< 400 KHz data transmission
#endif
// If 400 KHz support is enabled, the third parameter to the constructor
// requires a 16-bit value (in order to select 400 vs 800 KHz speed).
// If only 800 KHz is enabled (as is default on ATtiny), an 8-bit value
// is sufficient to encode pixel color order, saving some space.
#ifdef NEO_KHZ400
typedef uint16_t neoPixelType; ///< 3rd arg to Adafruit_NeoPixel constructor
#else
typedef uint8_t neoPixelType; ///< 3rd arg to Adafruit_NeoPixel constructor
#endif
// These two tables are declared outside the Adafruit_NeoPixel class
// because some boards may require oldschool compilers that don't
// handle the C++11 constexpr keyword.
/* A PROGMEM (flash mem) table containing 8-bit unsigned sine wave (0-255).
Copy & paste this snippet into a Python REPL to regenerate:
import math
for x in range(256):
print("{:3},".format(int((math.sin(x/128.0*math.pi)+1.0)*127.5+0.5))),
if x&15 == 15: print
static const uint8_t PROGMEM _NeoPixelSineTable[256] = {
128,131,134,137,140,143,146,149,152,155,158,162,165,167,170,173,
176,179,182,185,188,190,193,196,198,201,203,206,208,211,213,215,
218,220,222,224,226,228,230,232,234,235,237,238,240,241,243,244,
245,246,248,249,250,250,251,252,253,253,254,254,254,255,255,255,
255,255,255,255,254,254,254,253,253,252,251,250,250,249,248,246,
245,244,243,241,240,238,237,235,234,232,230,228,226,224,222,220,
218,215,213,211,208,206,203,201,198,196,193,190,188,185,182,179,
176,173,170,167,165,162,158,155,152,149,146,143,140,137,134,131,
128,124,121,118,115,112,109,106,103,100, 97, 93, 90, 88, 85, 82,
79, 76, 73, 70, 67, 65, 62, 59, 57, 54, 52, 49, 47, 44, 42, 40,
37, 35, 33, 31, 29, 27, 25, 23, 21, 20, 18, 17, 15, 14, 12, 11,
10, 9, 7, 6, 5, 5, 4, 3, 2, 2, 1, 1, 1, 0, 0, 0,
0, 0, 0, 0, 1, 1, 1, 2, 2, 3, 4, 5, 5, 6, 7, 9,
10, 11, 12, 14, 15, 17, 18, 20, 21, 23, 25, 27, 29, 31, 33, 35,
37, 40, 42, 44, 47, 49, 52, 54, 57, 59, 62, 65, 67, 70, 73, 76,
79, 82, 85, 88, 90, 93, 97,100,103,106,109,112,115,118,121,124};
/* Similar to above, but for an 8-bit gamma-correction table.
import math
gamma=2.6
print("{:3},".format(int(math.pow((x)/255.0,gamma)*255.0+0.5))),
static const uint8_t PROGMEM _NeoPixelGammaTable[256] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1,
1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3,
3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 5, 6, 6, 6, 6, 7,
7, 7, 8, 8, 8, 9, 9, 9, 10, 10, 10, 11, 11, 11, 12, 12,
13, 13, 13, 14, 14, 15, 15, 16, 16, 17, 17, 18, 18, 19, 19, 20,
20, 21, 21, 22, 22, 23, 24, 24, 25, 25, 26, 27, 27, 28, 29, 29,
30, 31, 31, 32, 33, 34, 34, 35, 36, 37, 38, 38, 39, 40, 41, 42,
42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57,
58, 59, 60, 61, 62, 63, 64, 65, 66, 68, 69, 70, 71, 72, 73, 75,
76, 77, 78, 80, 81, 82, 84, 85, 86, 88, 89, 90, 92, 93, 94, 96,
97, 99,100,102,103,105,106,108,109,111,112,114,115,117,119,120,
122,124,125,127,129,130,132,134,136,137,139,141,143,145,146,148,
150,152,154,156,158,160,162,164,166,168,170,172,174,176,178,180,
182,184,186,188,191,193,195,197,199,202,204,206,209,211,213,215,
218,220,223,225,227,230,232,235,237,240,242,245,247,250,252,255};
@brief Class that stores state and functions for interacting with
Adafruit NeoPixels and compatible devices.
class Adafruit_NeoPixel {
public:
// Constructor: number of LEDs, pin number, LED type
Adafruit_NeoPixel(uint16_t n, uint16_t pin=6,
neoPixelType type=NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel(void);
~Adafruit_NeoPixel();
void begin(void);
void show(void);
void setPin(uint16_t p);
void setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b);
void setPixelColor(uint16_t n, uint8_t r, uint8_t g, uint8_t b,
uint8_t w);
void setPixelColor(uint16_t n, uint32_t c);
void fill(uint32_t c=0, uint16_t first=0, uint16_t count=0);
void setBrightness(uint8_t);
void clear(void);
void updateLength(uint16_t n);
void updateType(neoPixelType t);
@brief Check whether a call to show() will start sending data
immediately or will 'block' for a required interval. NeoPixels
require a short quiet time (about 300 microseconds) after the
last bit is received before the data 'latches' and new data can
start being received. Usually one's sketch is implicitly using
this time to generate a new frame of animation...but if it
finishes very quickly, this function could be used to see if
there's some idle time available for some low-priority
concurrent task.
@return 1 or true if show() will start sending immediately, 0 or false
if show() would block (meaning some idle time is available).
bool canShow(void) {
if (endTime > micros()) {
endTime = micros();
return (micros() - endTime) >= 300L;
@brief Get a pointer directly to the NeoPixel data buffer in RAM.
Pixel data is stored in a device-native format (a la the NEO_*
constants) and is not translated here. Applications that access
this buffer will need to be aware of the specific data format
and handle colors appropriately.
@return Pointer to NeoPixel buffer (uint8_t* array).
@note This is for high-performance applications where calling
setPixelColor() on every single pixel would be too slow (e.g.
POV or light-painting projects). There is no bounds checking
on the array, creating tremendous potential for mayhem if one
writes past the ends of the buffer. Great power, great
responsibility and all that.
uint8_t *getPixels(void) const { return pixels; };
uint8_t getBrightness(void) const;
@brief Retrieve the pin number used for NeoPixel data output.
@return Arduino pin number (-1 if not set).
int16_t getPin(void) const { return pin; };
@brief Return the number of pixels in an Adafruit_NeoPixel strip object.
@return Pixel count (0 if not set).
uint16_t numPixels(void) const { return numLEDs; }
uint32_t getPixelColor(uint16_t n) const;
@brief An 8-bit integer sine wave function, not directly compatible
with standard trigonometric units like radians or degrees.
@param x Input angle, 0-255; 256 would loop back to zero, completing
the circle (equivalent to 360 degrees or 2 pi radians).
One can therefore use an unsigned 8-bit variable and simply
add or subtract, allowing it to overflow/underflow and it
still does the expected contiguous thing.
@return Sine result, 0 to 255, or -128 to +127 if type-converted to
a signed int8_t, but you'll most likely want unsigned as this
output is often used for pixel brightness in animation effects.
static uint8_t sine8(uint8_t x) {
return pgm_read_byte(&_NeoPixelSineTable[x]); // 0-255 in, 0-255 out
@brief An 8-bit gamma-correction function for basic pixel brightness
adjustment. Makes color transitions appear more perceptially
correct.
@param x Input brightness, 0 (minimum or off/black) to 255 (maximum).
@return Gamma-adjusted brightness, can then be passed to one of the
setPixelColor() functions. This uses a fixed gamma correction
exponent of 2.6, which seems reasonably okay for average
NeoPixels in average tasks. If you need finer control you'll
need to provide your own gamma-correction function instead.
static uint8_t gamma8(uint8_t x) {
return pgm_read_byte(&_NeoPixelGammaTable[x]); // 0-255 in, 0-255 out
@brief Convert separate red, green and blue values into a single
"packed" 32-bit RGB color.
@param r Red brightness, 0 to 255.
@param g Green brightness, 0 to 255.
@param b Blue brightness, 0 to 255.
@return 32-bit packed RGB value, which can then be assigned to a
variable for later use or passed to the setPixelColor()
function. Packed RGB format is predictable, regardless of
LED strand color order.
static uint32_t Color(uint8_t r, uint8_t g, uint8_t b) {
return ((uint32_t)r << 16) | ((uint32_t)g << 8) | b;
@brief Convert separate red, green, blue and white values into a
single "packed" 32-bit WRGB color.
@param w White brightness, 0 to 255.
@return 32-bit packed WRGB value, which can then be assigned to a
function. Packed WRGB format is predictable, regardless of
static uint32_t Color(uint8_t r, uint8_t g, uint8_t b, uint8_t w) {
return ((uint32_t)w << 24) | ((uint32_t)r << 16) | ((uint32_t)g << 8) | b;
static uint32_t ColorHSV(uint16_t hue, uint8_t sat=255, uint8_t val=255);
@brief A gamma-correction function for 32-bit packed RGB or WRGB
colors. Makes color transitions appear more perceptially
correct.
@param x 32-bit packed RGB or WRGB color.
@return Gamma-adjusted packed color, can then be passed in one of the
setPixelColor() functions. Like gamma8(), this uses a fixed
gamma correction exponent of 2.6, which seems reasonably okay
for average NeoPixels in average tasks. If you need finer
control you'll need to provide your own gamma-correction
function instead.
static uint32_t gamma32(uint32_t x);
protected:
#ifdef NEO_KHZ400 // If 400 KHz NeoPixel support enabled...
bool is800KHz; ///< true if 800 KHz pixels
#endif
bool begun; ///< true if begin() previously called
uint16_t numLEDs; ///< Number of RGB LEDs in strip
uint16_t numBytes; ///< Size of 'pixels' buffer below
int16_t pin; ///< Output pin number (-1 if not yet set)
uint8_t brightness; ///< Strip brightness 0-255 (stored as +1)
uint8_t *pixels; ///< Holds LED color values (3 or 4 bytes each)
uint8_t rOffset; ///< Red index within each 3- or 4-byte pixel
uint8_t gOffset; ///< Index of green byte
uint8_t bOffset; ///< Index of blue byte
uint8_t wOffset; ///< Index of white (==rOffset if no white)
uint32_t endTime; ///< Latch timing reference
#ifdef __AVR__
volatile uint8_t *port; ///< Output PORT register
uint8_t pinMask; ///< Output PORT bitmask
#endif
#if defined(ARDUINO_ARCH_STM32) || defined(ARDUINO_ARCH_ARDUINO_CORE_STM32)
GPIO_TypeDef *gpioPort; ///< Output GPIO PORT
uint32_t gpioPin; ///< Output GPIO PIN
#endif
#endif // ADAFRUIT_NEOPIXEL_H
