Hi everyone!
I'm trying to "command" different FX_MODEs from the WS2812FX library using midi notes from Ableton Live through Hairless Midi.
I have 5 LED stripes of 60 (WS2812B) neopixels (300 in total), and a UNO powered by USB + 2 extra 5v 10A supplies for the LEDs.
I'm giving the signal to the LEDs through pin 8 with 470Ohm resistor across and 1000uf capacitor on the power.
I am able to light up single LEDs with single notes, and to run the WS2812FX library effect modes smoothly but am unable to write the code to trigger certain FX_MODE by a specific note.
The aim being that i attach all of the 128 notes to an FX mode of my choice to be recalled on the piano roll of Ableton live and thus be in sync with tracks being played...
Here is the code that i use for choosing & displaying FX_MODE
#include <WS2812FX.h>
#define LED_PIN 8 // digital pin used to drive the LED strip
#define LED_COUNT 300 // number of LEDs on the strip
WS2812FX ws2812fx = WS2812FX(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
ws2812fx.init();
ws2812fx.setBrightness(128);
// parameters: index, start, stop, mode, color, speed, reverse
//ws2812fx.setSegment(0, 0, 9, FX_MODE_BLINK, 0xFF0000, 1000, false); // segment 0 is leds 0 - 9
ws2812fx.setSegment(0, 0, 299, FX_MODE_MULTI_STROBE, 0xF65D94, 920, false); // segment 2 is leds 20 - 29
ws2812fx.start();
ws2812fx.service();
and here the code that blinks LEDs as i press notes on Midi keyboard:
#include <MIDI.h>
#include "FastLED.h" //We are using the FastLED library instead of the Adafruit Neopixel library, to work better with Teensy
#define LED_PIN 8
#define NUM_LEDS 300
#define BRIGHTNESS 90
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
#define UPDATES_PER_SECOND 200
struct HairlessMidiSettings : public midi::DefaultSettings
static const bool UseRunningStatus = false;
static const long BaudRate = 115200;
MIDI_CREATE_CUSTOM_INSTANCE(HardwareSerial, Serial, MIDI, HairlessMidiSettings);
//Palette setup
CRGBPalette16 currentPalette;
TBlendType currentBlending;
extern CRGBPalette16 RainbowColors;
extern const TProgmemPalette16 RainbowColors_p PROGMEM;
//Set variables for velocity (color) and note (LED position on ring)
uint8_t NewVelocity;
uint8_t NewNote;
//MIDI handles to set up actions on note on and note off
MIDI.setHandleNoteOff(OnNoteOff);
MIDI.setHandleNoteOn(OnNoteOn) ;
//Setting up LED info for the FastLED library
FastLED.addLeds<LED_TYPE, 8, GRB >(leds, 300).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( 200 );
currentPalette = RainbowColors_p;
currentBlending = LINEARBLEND;
//Turn on one red LED to show sketch has started
leds[0] = CRGB::Red;
FastLED.show();
leds[0] = CRGB::Black;
FastLED.show();
//Print OK for start
// Serial.print("---------------- START SUCCESSFUL ----------------");
//*** Running program loop ***
//This is all we need, since we have actions set when MIDI is read
MIDI.read();
//Functions defined below
//What to do if MIDI note on is read
void OnNoteOn(byte channel, byte note, byte velocity)
NewNote = note; ///note/8
//this reduces notes to 16 LEDs - change to suit different setup
//NewVelocity = 128 - velocity; // do this so palette goes from blue to red with higher velocity
VelocityColorFromPalette( NewVelocity); //Go do the routine we have defined below, to set up color depending on velocity
FastLED.show(); //Turn on that LED when you get back from the color routine
//Uncomment lines below to print values to Serial Monitor if needed
Serial.println("Note On, ch=1");
Serial.print(channel, DEC);
Serial.println(", NewNote=");
Serial.println(note, DEC);
Serial.print(", velocity=");
Serial.print(velocity, DEC);
//What to do if MIDI note off is read
void OnNoteOff(byte channel, byte note, byte velocity)
///////// if i put num_leds - 5 (minus 5) it'll crash, so DON'T!!!!
///// test to see if the bastard gets lower than 0 so it won't crash
if((note <= NUM_LEDS )){
leds[note] = CRGB::Black; //Set color to black instead of going to the color from velocity routine
FastLED.show(); //turn off that LED by making it black
void VelocityColorFromPalette( uint8_t colorIndex)
uint8_t brightness = BRIGHTNESS; //This takes the brightness from the BRIGHTNESS variable we set at the top
colorIndex = NewVelocity; //This makes the colorIndex in the FastLED ColorFromPalette command follow our velocity
if((NewNote <= NUM_LEDS )){
leds[NewNote] = ColorFromPalette( currentPalette, colorIndex, brightness, currentBlending); //Set those colors and brightness
Any help is greatly appreciated!
