Bl4ck_B0y:
Yeah, I've checked ws2812b and ws2811 with the same parameters (amount of LEDs/m, waterproof certificate) and looks like 11 is cheaper. Not sure, but it may be because of 3 times less LED controllers.
Yes, it just might be. It's hard to balance up the manufacturing costs of these things but going by eBay, it seems that WS2812s are at least 25 cents each and tricolour LEDs themselves are presumably much cheaper.
Bl4ck_B0y:
Anyway, if I'm back at 12b, can this step-down be good enough?
DC-DC 5V 3A
I know that those 3 amps are max value and normal operational is 1,5A, but can I just use this max value in my calculations?
If as you say, you will probably use only one colour of one led at a time, that will make sense.
Bl4ck_B0y:
In my project I will probably use only one color of one led at a time. In this case I would need 12 of those converters, which is still cheaper than this one: DC-DC 5V 40A
So it seems. And the 40 Amp one specifies 20 V maximum while the 3 A one says 28 V, so there appears to be a better safety margin!
Also, if one fails, you have limited the replacement cost!
By the way, the 3 A listing has a starting shipping cost, have you noticed how on aliexpress, ordering multiple (small) items switches from free shipping to a significant fee?
And I love this picture:
Magnify!
Bl4ck_B0y:
By less power consumption i was thinking about how ws2812b 60LEDs/m are ~18W/m and ws2811 are ~14W/m.
Not a great deal and that latter power consumption is quoted/ calculated at 12 V, not 14 V, so you can add 2 W!
Bl4ck_B0y:
But now: what will be the best way to make it as cheap as possible without everything getting burned and to make it actually work?
I am still siding with the 5 V strips and multiple converters. Note the need for the capacitors, we have still not quite reconciled with Mike, but it might amuse him to look at this module:
You are certainly having an excellent lesson here in industrial design.
