How do I add code for WS2812C? It doesn't seem to be in fast.led library.
thanks for any help
thanks for any help
From what I found the WS2812C is compatible/interchangeable with the WS2812 & WS2812B (reference).
Adafruit NeoPixel Uber Guide. They feature their own library (I don't know how it compares to fast.led) but there's a TON of useful information
Thank you. I dd try adding WS2812(B) but neither would compile.
I will try AdaFruit
ACME
Why did you required to add anything? The W2812B support is already in FastLed.
Please insert your code that didn't compile and show the error messages
I was referring to the instruction
FastLED.addLeds
I am running an example from the fast.Led library and changed "WS2812B" to 'WS2812C"
I got this error:
:\Users\Thomas\Documents\Arduino\TestingStrip\TestingStrip.ino: In function 'void setup()':
C:\Users\Thomas\Documents\Arduino\TestingStrip\TestingStrip.ino:35:21: error: 'WS2812C' was not declared in this scope
FastLED.addLeds<WS2812C, DATA_PIN, RGB>(leds, NUM_LEDS); // GRB ordering is typical
C:\Users\Thomas\Documents\Arduino\TestingStrip\TestingStrip.ino:35:21: note: suggested alternative: 'WS2812B'
WS2812B
C:\Users\Thomas\Documents\Arduino\TestingStrip\TestingStrip.ino:35:59: error: no matching function for call to 'CFastLED::addLeds<, 3, RGB>(CRGB [4], int)'
In file included from C:\Users\Thomas\Documents\Arduino\TestingStrip\TestingStrip.ino:6:0:
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:267:130: note: candidate: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER, long unsigned int SPI_DATA_RATE> CLEDController& CFastLED::addLeds(CRGB*, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER, uint32_t SPI_DATA_RATE > CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:267:130: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\TestingStrip\TestingStrip.ino:35:59: error: template argument 1 is invalid
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:282:95: note: candidate: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN > static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:282:95: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:297:113: note: candidate: template<ESPIChipsets CHIPSET, unsigned char DATA_PIN, unsigned char CLOCK_PIN, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, uint8_t DATA_PIN, uint8_t CLOCK_PIN, EOrder RGB_ORDER > static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:297:113: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:312:56: note: candidate: template static CLEDController& CFastLED::addLeds(CRGB, int, int)
template static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:312:56: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\TestingStrip\TestingStrip.ino:35:59: error: wrong number of template arguments (3, should be 1)
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:316:74: note: candidate: template<ESPIChipsets CHIPSET, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, EOrder RGB_ORDER> static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:316:74: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\TestingStrip\TestingStrip.ino:35:59: error: wrong number of template arguments (3, should be 2)
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:320:98: note: candidate: template<ESPIChipsets CHIPSET, EOrder RGB_ORDER, long unsigned int SPI_DATA_RATE> static CLEDController& CFastLED::addLeds(CRGB, int, int)
template<ESPIChipsets CHIPSET, EOrder RGB_ORDER, uint32_t SPI_DATA_RATE> static CLEDController &addLeds(struct CRGB data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:320:98: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:351:25: note: candidate: template<template<unsigned char DATA_PIN, EOrder RGB_ORDER> class CHIPSET, unsigned char DATA_PIN, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:351:25: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:358:25: note: candidate: template<template<unsigned char DATA_PIN, EOrder RGB_ORDER> class CHIPSET, unsigned char DATA_PIN> static CLEDController& CFastLED::addLeds(CRGB, int, int)
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:358:25: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:365:25: note: candidate: template<template class CHIPSET, unsigned char DATA_PIN> static CLEDController& CFastLED::addLeds(CRGB, int, int)
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:365:25: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:413:25: note: candidate: template<template class CHIPSET, EOrder RGB_ORDER> static CLEDController& CFastLED::addLeds(CRGB, int, int)
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:413:25: note: template argument deduction/substitution failed:
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:420:25: note: candidate: template<template class CHIPSET> static CLEDController& CFastLED::addLeds(CRGB, int, int)
static CLEDController &addLeds(struct CRGB *data, int nLedsOrOffset, int nLedsIfOffset = 0) {
C:\Users\Thomas\Documents\Arduino\libraries\FastLED\src/FastLED.h:420:25: note: template argument deduction/substitution failed:
exit status 1
Compilation error: 'WS2812C' was not declared in this scope
C:\Users\Thomas\Documents\Arduino\TestingStrip\TestingStrip.ino: In function 'void setup()':
WS2812B
exit status 1
You must not to change it. Just use "WS2812B" as led type:
FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
Yes. I ran it this way and then with the instruction for WS3812 and the strip did not work.
Does this mean the strip must be faulty?
