WS2812FX Library and Button Use for Show Switching
I am having a freak job of trying to get kitesurfer1404’s to swap shows using a button. I cannot seem to get the show started or when it starts I cannot get it to pause on the desired show.
This is what I have assembled…
// The WS2812FX is used in this sketch: https://github.com/kitesurfer1404/WS2812FX
// All cred goes to this developer
// I have started building this also based on the basic button systems
// This was designed for my wife who wanted more control over her infinity mirror
#include <WS2812FX.h>
#define LED_COUNT 107
#define LED_PIN 6
WS2812FX ws2812fx = WS2812FX(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
byte changeButton = 2; // wire button to connect pin to Gnd when pressed
byte programSelect = 0;
  ws2812fx.init();
  ws2812fx.setBrightness(250);
  ws2812fx.setSpeed(100);
  ws2812fx.start();
  pinMode (changeButton, INPUT_PULLUP); //
if (digitalRead(changeButton == LOW)){ // requires user to press & hold button near end of a routine to go on to the next one, otherwise repeat current
programSelect = programSelect +1;
  if (programSelect == 10){
  programSelect = 0; // reset, assume 10 programs, #0 to #9
  ws2812fx.service();
switch (programSelect){
case 0:
  ws2812fx.setMode(FX_MODE_RAINBOW_CYCLE);
case 1:
  ws2812fx.setMode(FX_MODE_THEATER_CHASE_RAINBOW);
case 2:
  ws2812fx.setMode(FX_MODE_MERRY_CHRISTMAS);
case 3:
  ws2812fx.setMode(FX_MODE_CHASE_RANDOM);
case 4:
  ws2812fx.setMode(FX_MODE_FIREWORKS);
case 5:
  ws2812fx.setMode(FX_MODE_HYPER_SPARKLE);
case 6:
  ws2812fx.setMode(FX_MODE_SCAN);
case 7:
  ws2812fx.setMode(FX_MODE_MULTI_DYNAMIC);
case 8:
  ws2812fx.setMode(FX_MODE_CHASE_BLACKOUT);
case 9:
  ws2812fx.setMode(FX_MODE_COMET);
} // end switch
} // end loop
Any guidance would be appreciated. I am novice at this but learn fast. I don’t need anyone to code it for me just direct me where where to put the commands.
Yes that is to be expected if you only check the button at the end of a display routine. To do things properly you have to write the various display patterns as a state machine.
The other simple way is to replace calles to delay with a call of your own that uses the millis timer and when the button is held down the delay terminates, allowing you to drop out of any pattern.
Thank you for the guidance. I will work a couple of different models and if successful.... I will report back.
