Hello,
I’m working on a project that will simulate the output of a frequency analyser - it’s basically a 20 pixel high four pixel wide grid of WS8212B RGB tape. - Each column ‘bounces’ up and down, red at the top, green at the bottom sort of thing…
After a few failed attempts at getting them to run concurrently, I found this Neomatrix EQ Bar Library which looked like it would very easily do exactly what I needed it to.
At first it wasn’t working - I narrowed it down to the colorwheel code in the library, and worked around it by building my own colours in. After this I had one column of pixels doing exactly as I needed it to.
The documentation on Github explains how to then duplicate this over multiple columns - and this is where I’m completely stuck. I’ve tried both of the listed methods (repeating code and for loops) - as soon as you add another column the code compiles but does absolutely nothing.
I put a number of serial prints in to see where the code was getting stuck, and it wasn’t running at all, sometimes with gibberish being sent to the serial monitor.
#include "NeoMatrixEqBar.h"
//matrix constants
const int MATRIX_PIN = 6;
const int MATRIX_WIDTH = 4;
const int MATRIX_HEIGHT = 20;
const int MATRIX_PIXEL_TYPE = NEO_RGB + NEO_KHZ800;
const int MATRIX_BRIGHTNESS = 10;
//animation speed
//lower values means FASTER!
const int speed = 40;
//matrix setup
const int MATRIX_OPTIONS =
NEO_MATRIX_TOP +
NEO_MATRIX_LEFT +
NEO_MATRIX_COLUMNS +
NEO_MATRIX_PROGRESSIVE;
//declare the matrix
Adafruit_NeoMatrix matrix =
Adafruit_NeoMatrix(
MATRIX_WIDTH,
MATRIX_HEIGHT,
MATRIX_PIN,
MATRIX_OPTIONS,
MATRIX_PIXEL_TYPE);
/* build a Neo Matrix EQ bar
&matrix - a pointer to the matrix.
0 - which column
0 - starting height
MATRIX_HEIGHT - the EQ bar's max height;
NeoMatrixEqBar eqBars[4];
Serial.println("start");
//init the matrix
matrix.begin();
matrix.setBrightness(MATRIX_BRIGHTNESS);
matrix.clear();
matrix.show();
//build the EQ bars, one for each column of our matrix
for (int i = 0; i < MATRIX_WIDTH; i++) {
0 - which column
0 - starting height
NeoMatrixEqBar eqBar = NeoMatrixEqBar(&matrix, i, 0, MATRIX_HEIGHT);
//init the eqBar
eqBar.begin();
eqBar.randomizeSpeed(true);
//add to the array
eqBars[i] = eqBar;
//tick the EQ bars to update them
eqBars[i].tick();
matrix.show();
delay(speed);
matrix.clear();
Please can anyone shed any light on why this is happening? I know the loops are working, as reducing ‘MATRIX_WIDTH’ to 1 has it working as before…
Also not sure if it’s relevant but for some reason it’s upside down… setting MATRIX_TOP fixes this, even though it’s technically incorrect.
Thanks in advance for any advice
