I want to use a chip that is only in "wson-10" packaging.
I have not used wson-10.
A few searches came up empty on the size/pin spacing to see if I can use a soic or ssop or other breakout board for proptotyping. Or better, someone knows of a wson-10 breakout board pre-made?
Look at the data sheet link provided by mouser, look at the last couple of pages and that will give you the physical chip dimensions.
This link will help.
http://www.lapis-semi.com/en/data/drawing-file/draw_wson10.pdf
Then gargle the other sizes and check the dimensions.
Tom....
