I have this problem !
C:\Users\spiro\Documents\Arduino\SimpleAuthentication\SimpleAuthentication.ino: In function 'void setup()':
C:\Users\spiro\Documents\Arduino\SimpleAuthentication\SimpleAuthentication.ino:167:12: error: no matching function for call to 'ETHClass::begin(int, int)'
167 | ETH.begin(ETH_PHY_ADDR, ETH_PHY_POWER);
In file included from c:\Users\spiro\Documents\Arduino\libraries\WebServer_WT32_ETH01\src/WebServer_WT32_ETH01.hpp:76,
from c:\Users\spiro\Documents\Arduino\libraries\WebServer_WT32_ETH01\src/WebServer_WT32_ETH01.h:72,
from C:\Users\spiro\Documents\Arduino\SimpleAuthentication\SimpleAuthentication.ino:18:
C:\Users\spiro\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Ethernet\src/ETH.h:126:8: note: candidate: 'bool ETHClass::begin(eth_phy_type_t, int32_t, int, int, int, eth_clock_mode_t)'
126 | bool begin(eth_phy_type_t type, int32_t phy_addr, int mdc, int mdio, int power, eth_clock_mode_t clk_mode);
C:\Users\spiro\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Ethernet\src/ETH.h:126:8: note: candidate expects 6 arguments, 2 provided
C:\Users\spiro\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Ethernet\src/ETH.h:129:8: note: candidate: 'bool ETHClass::begin(eth_phy_type_t, int32_t, int, int, int, SPIClass&, uint8_t)'
129 | bool begin(eth_phy_type_t type, int32_t phy_addr, int cs, int irq, int rst, SPIClass &spi, uint8_t spi_freq_mhz = ETH_PHY_SPI_FREQ_MHZ);
C:\Users\spiro\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Ethernet\src/ETH.h:129:8: note: candidate expects 7 arguments, 2 provided
C:\Users\spiro\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Ethernet\src/ETH.h:131:8: note: candidate: 'bool ETHClass::begin(eth_phy_type_t, int32_t, int, int, int, spi_host_device_t, int, int, int, uint8_t)'
131 | bool begin(
C:\Users\spiro\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Ethernet\src/ETH.h:131:8: note: candidate expects 10 arguments, 2 provided
C:\Users\spiro\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Ethernet\src/ETH.h:136:8: note: candidate: 'bool ETHClass::begin()'
136 | bool begin() {
C:\Users\spiro\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.1\libraries\Ethernet\src/ETH.h:136:8: note: candidate expects 0 arguments, 2 provided
exit status 1
Compilation error: no matching function for call to 'ETHClass::begin(int, int)'
