Wt32-eth01 pcb files
I dont suppose anyone has the schematic and pcb components to import into designspark pcb?
You would probably stand a better chance of getting a reply if you posted this question in either the "General Electronics" or "Networking" areas.
@bruton
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
In the original location i received 2 replies but in the new location i receive no replies
What is it you want? A quick google search for "WT32-ETH01" brings up images of an ethernet module with standard 0.1in pitch pins. It should be simple to create a package based around a 26-pin DIL footprint (or a modified one if the module width doesn't match a standard DIL package footprint).
I had never had much success with creating footprints but had to learn but was successful this time
thought id update
When I wanted to mount an ESP8266 board on a PCB I just used the footprint for 2 connectors with 0.1" pin spacing and the right number of pins. Carefully spaced out on the board they worked as required.
Ive done that with other stuff in past but i also needed schematic symbol to create propper schematic
