I recently purchased a WT901 because i am trying to program/create a solar tracker (multi-axis). Though, the WT901 sensor seems to not be reading the rotational value correctly. Any ideas on why it could be. It seems to drift some, though when i have it hooked up directly to my pc and connected to the WIT app, it seems to be fine. I've tried re-calibrating it, getting a new one, still to no success. Any ideas would be helpful!
(I AM JUST PUTTING THIS HERE TO SEE IF ANYONE ELSE HAS THIS PROBLEM WITH THE SENSOR, I AM NOT SUPPLYING ANY CODE TO BE DEBUGGED OR ANYTHING LIKE THAT, JUST A PROBLEM WITH THE SENSOR)
If the sensor works OK with the PC app but not with the Arduino it sounds like the problem is with the connection to the Arduino, the code running on the Arduino or the power supply to the Arduino
Yeah, thats why i was asking for ideas. I am using the library provided by the manufacturer, so i can almost rule that out. The power is 5v from the Arduino, so im ruling that out, and i know i have a good power supply on the Arduino. So any other ideas would be helpful
