Dear Forum,
I am currently trying to use the BLYNK app (on a smartphone) to wirelessly control an MP3/sdCard module (Wtv020sd16p). There is an excellent tutorial on the Wtv020sd16p here Arduino mp3 module Tutorial - wtv020sd16p: Code, Connect, and Run! - YouTube .
I am using an HM-10 Bluetooth module as the slave. I have written some code to communicate between my phone and serial monitor. I installed the BLE Terminal app on my smartphone and I can confirm that the serial communication works great.
Martyn Currey has an excellent tutorial on this here HM-10 Bluetooth 4 BLE Modules | Martyn Currey . With Martyn's code, I was able to change the HM-10 baud rate...very cool.
I have already tried to increase the baud rate to 57600, but the BLE Terminal app only allows 9600. I have an e-mail into their tech support to figure out how to change the baud rate. This feature is probably available on the purchased version, and I will be happy to purchase the app if I can get this functionality.
The only problem that I seem to be having is when I create an instance of the WTV020SD16P class. This seems to interfere with the both the hardware and software serial ports. I currently have the line commented out.
I looked at the wtv020sd16p.cpp code (WTV020SD16P/WTV020SD16P.cpp at master · theFPVgeek/WTV020SD16P · GitHub ) and the only thing that I can think of is that there is a timing issue. The WTV code has some very small delays on the order of microseconds, and I wonder if this is creating an issue for the serial ports.
TIA,
--Neal
#include <stdio.h>
#include <stdint.h>
#include <BlynkSimpleSerialBLE.h>
#include <WTV020SD16P.h>
#include <SoftwareSerial.h>
#define extSpkr A0
#define intSpkr A1
//#define BLYNK_USE_DIRECT_CONNECT
//#define BLYNK_PRINT Serial
char auth[] = "tbd";
int resetPin = 4;
int clockPin = 5;
int dataPin = 6;
int busyPin = 7;
int track;
//WTV020SD16P wtv020sd16p(resetPin, clockPin, dataPin, busyPin);
SoftwareSerial mySerial(8,9); // RX(8), TX(9) these pins must be for AltSoftSerial
while (!Serial) ; // wait for Arduino Serial Monitor to open
mySerial.begin(9600);
//Blynk.begin(SerialBLE, auth);
pinMode(extSpkr, INPUT);
pinMode(dogSpkr, INPUT);
//wtv020sd16p.reset();
char c;
if (Serial.available())
c = Serial.read();
mySerial.print(c);
if (mySerial.available())
c = mySerial.read();
Serial.print(c);
