X and Y integer loops
Hello,
Apologies if this is fairly simple, but I am trying to make sure I have my foundations right for a project I am working on which basically pans and tilts a camera to take images along the X and Y axis to later be combined into a gigapan style image.
So I calculate the xMax and xMin positions, as well as the yMax and yMin positions to end up with a yTotal and xTotal (the total degrees across the respective axis)
From there, I also calculate the number of degrees the given camera and lens (e.g. focal length) will cover accounting for some overlap.
Knowing the number of degrees the lens covers, I can do a simple yTotal / yLensDegrees to work out how many images I need to capture along the Y axis which is fine.
Say I need to capture 3 images across the Y axis, and 10 images along the X axis and I know the lens covers 20 degrees along the X, and 15 degrees along the Y what is the best way to loop these given I need to give absolute commands to the servo (e.g. move to position 45 degrees along x).
I thought about doing an integer loop which would still work, but just not sure how to handle the increasing servo position, should I just do something like a simple integer loop but start at 1 instead of zero, and move finish at the endpoint+1, then I could just multiply the integer loop number by the number of degrees the lens covers and send that to the servo as an absolute position?
Just wondering if there is a better way to do it than that, or if not does anyone foresee any problems?
Many thanks!
I believe you are (close to) describing... https://en.wikipedia.org/wiki/Bresenham's_line_algorithm
If I understand you correct you just want to photograph a matrix of x * y photo’s? That’s just math… So you mean something like:
Servo servoX;
Servo servoY;
const byte StartX = ;
const byte StartY = ;
const byte StepSizeX = ;
const byte StepSizeY = ;
const byte StepsX = ;
const byte StepsY = ;
void setup(){
  //attach servo etc
void loop(){
  for(byte x = 0; x < StepsX; x++){
    servoX.write(x * StepSizeX + StartX);
    for(byte y = 0; y < StepsY; y++){
      if(x % 2){
        servoY.write((StepsY - y) * StepSizeY + StartY);
      else{
        servoY.write(y * StepSizeY + StartY);
      //take photo
This will zigzag in the Y direction while sweeping the X.
Code is not complete, just for you idea.
Thanks for your help Septillion, and Coding badly, it was not so much the zig zagging I need as I can go left to right, then up one, back to the far left, then continue going left to right, moving up a line at a time.
The code put me in the right direction though, I made a few minor modifications and added some debug so I could see what was happening when I used some servo’s.
Thanks for the help, most appreciated!
void loop(){
  for(byte y = 0; y < Stepsy; y++){
    servoy.write(y * StepSizey + Starty);
    for(byte x = 0; x < Stepsx; x++){
     servox.write(x * StepSizex + Startx);
     Serial.print("y position:");
     Serial.print(y);
     Serial.print("(");
     Serial.print(y * StepSizey + Starty);
     Serial.print(")");
     Serial.print(", x position:");
     Serial.print(x);
          Serial.print("(");
     Serial.print(x * StepSizex + Startx);
     Serial.println(")");
      //take photo
Sorry, another quick one but related, with I use the code above I pan right to left then up. How do I go about changing the direction of the x loop, so I go the other direction.
I will need to change the StartX to FinishX and it becomes a subtraction and then of course define the const byte finishx = 75; for example, but I couldn't get the servo to change direction, it either did not move, or worse it was like it was being skipped and just the Y loop was going crazy :(
I used the zigzag because that seems to me like the quickest way / shortest travel and the shortest possible time between to adjoining photo’s.
But then:
void loop(){
      servox.write((StepsX - x) * StepSizex + Startx);
      Serial.print(y);
      Serial.print("(");
      Serial.print(")");
      Serial.print(x);
          Serial.print("(");
      Serial.print((StepsX - x) * StepSizex + Startx);
      //take photo
And StepsY, StepSizeY etc is more readable then Stepsy and StepSizey. More clear that you mean something with Y instead of the word stepsy, because what is a stepsy?
Works fantastically, good point about my variable capitalization :)
Thanks again for your help!
