Greetings! So I am currently sending the values from an X Bees RSSI pin to another X Bee and reading the incoming values, then printing on an LCD.
problem: The incoming values are only showing a range of 0-43ish. I want to see values extending to the 300ft range. I'm not sure what I am doing wrong. Here is my AT commands for each xbee, along with my sender and receiver code:
Receiver emitter(everything same as receiver except ones listed)
ATID4256
ATP01
ATIR0
ATCE0 ATCE1
ATBD5
ATM02
ATRP10
// Emitter Code for xbee RSSI pin
const int rssi_pin = 9; //RSSI Pin of the XBee Module
int rssiDur; //variable to read pin
byte inches_val;
//LED pins//////////////////////////
const int led3 = 3;
const int led4 = 4;
const int led5 = 5;
const int led6 = 6;
const int led7= 7;
const int led8= 8;
const int led10= 10;
const int led11= 11;
const int led12= 12;
const int led13= 13;
///Averager Variables///////////////////////////////
//this is intended to place first 10 read incoming RSSI values in an array and average. smoother readings
const int numReadings = 10;
int readings[numReadings]; // the readings from the RSSI
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
void setup(){
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
pinMode (led3, OUTPUT);
pinMode (led4, OUTPUT);
pinMode (led5, OUTPUT);
pinMode (led6, OUTPUT);
pinMode (led7, OUTPUT);
pinMode (led8, OUTPUT);
pinMode (led10, OUTPUT);
pinMode (led11, OUTPUT);
pinMode (led12, OUTPUT);
pinMode (led13, OUTPUT);
Serial.begin(38400); //Xbee communicating at this baud
void loop(){
rssiDur = pulseIn(rssi_pin, LOW, 200); //this is set to 200ms with ATRP @ 2
inches_val = rssiDur ;
total= total - readings[index];
// read from the sensor:
readings[index] = inches_val;
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// calculate the average:
average = total / numReadings;
Serial.write(average);
delay(100); // delay in between rea
// value 10 = 1 meter
if (average > 18 && average < 196){ //1-5 meters
// Serial.write(1);
digitalWrite(led3, HIGH);
digitalWrite(led4, HIGH);
digitalWrite(led5, HIGH);
digitalWrite(led6, HIGH);
digitalWrite(led7, HIGH);
digitalWrite(led8, HIGH);
digitalWrite(led10, HIGH);
digitalWrite(led11, HIGH);
digitalWrite(led12, HIGH);
digitalWrite(led13, HIGH);
if (average > 196 && average < 393){ //5-10 meters
//Serial.write(2);
digitalWrite(led12, LOW);
digitalWrite(led13, LOW);
if (average > 393 && average < 590){ //10- 15 meters
//Serial.write(3);
digitalWrite(led10, LOW);
digitalWrite(led11, LOW);
if (average > 590 && average < 787){ //15-20 meters
//Serial.write(4);
digitalWrite(led7, LOW);
digitalWrite(led8, LOW);
if (average > 787 ){ //20-30 meters
// Serial.write(5);
digitalWrite(led5, LOW);
digitalWrite(led6, LOW);
...and the receiver
#include <LiquidCrystal.h>
const int ledPin = 13;
//const int signalStrengthPin = 9;
byte incomingByte, val_read;
//int RSSIpin = 9;
//unsigned long rssiDur;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(16,2);
lcd.noAutoscroll();
pinMode(ledPin, OUTPUT);
// pinMode(signalStrengthPin, INPUT);
//rssiDur = pulseIn(RSSIpin, LOW, 200);
// print signal strength
//Serial.println(rssiDur);
if (Serial.available()>0)
// incomingByte = Serial.read();
//Serial.print(" Byte: ");
//Serial.println(incomingByte);
//delay(100);
//while ((int(incomingByte) == 1)) {
val_read = Serial.read();
//Serial.print("Svalues =");
//int inches = val_read / mathbyte;
Serial.println(int(val_read));
delay(100);
//Serial.print(int(inches));
lcd.setCursor(0,0);
lcd.print("Bike1=");
lcd.print(int(val_read), DEC);
