Hi there,
I tried to get the communication between x-IMU and my Arduino UNO running. So far, they communicate but the output is very disappointing:
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
ERROR: 12
battery = -7.00, thermometer = 36.17
This is the code i have configured:
it was written for Arduino MEGA, so i had to set the second serial to a softwareserial.
Then i connected my x-IMU Sensor with the digital PIN 10 on the Arduino UNO (which pretends now to be a RX).
Original Source: GitHub - xioTechnologies/x-BIMU-Arduino-Example
Would appreciate any suggestions!
Thanks in advance, milla
x_IMU_Arduino_Example.ino
Author: Seb Madgwick
Example usage of x-IMU C++ library. Also uses the quaternion library to
convert the received quaternion to Euler angles.
Requires two hardware serial modules: one to receive from the x-IMU and one
to transmit the decoded data to be displayed on computer.
x-IMU settings:
Auxiliary Port > Auxiliary Port Mode: "UART"
Auxiliary Port > UART > Baud Rate: 115200
Auxiliary Port > UART > Hardware Flow Control: Off
Hardware connections:
x-IMU GND -> Arduino MEGA GND
x-IMU EXT -> Arduino MEGA 5V
x-IMU AX2 -> Arduino MEGA RX1
Tested with "arduino-1.0.3" and "Arduino MEGA".
// Includes
#include "Quaternion.h"
#include "XimuReceiver.h"
#include "SoftwareSerial.h"
// Variables
XimuReceiver ximuReceiver;
SoftwareSerial mySerial(10,11);
// Functions
Serial.begin(115200); // for sending data to computer
mySerial.begin(115200); // for receiving data from x-IMU
ErrorCode e = ERR_NO_ERROR;
// Process recieved data
while(mySerial.available() > 0) {
e = ximuReceiver.processNewChar(mySerial.read());
// Print error code (receive error)
if(e != ERR_NO_ERROR) {
Serial.print("ERROR: ");
Serial.print(e);
Serial.print("\r");
// Print battery and thermometer data
if(ximuReceiver.isBattAndThermGetReady()) {
BattAndThermStruct battAndThermStruct = ximuReceiver.getBattAndTherm();
Serial.print("battery = ");
Serial.print(battAndThermStruct.battery);
Serial.print(", thermometer = ");
Serial.print(battAndThermStruct.thermometer);
Serial.print("\r");
// Print sensor data
if(ximuReceiver.isInertialAndMagGetReady()) {
InertialAndMagStruct inertialAndMagStruct = ximuReceiver.getInertialAndMag();
Serial.print("gyrX = ");
Serial.print(inertialAndMagStruct.gyrX);
Serial.print(", gyrY = ");
Serial.print(inertialAndMagStruct.gyrY);
Serial.print(", gyrZ = ");
Serial.print(inertialAndMagStruct.gyrZ);
Serial.print(", accX = ");
Serial.print(inertialAndMagStruct.accX);
Serial.print(", accY = ");
Serial.print(inertialAndMagStruct.accY);
Serial.print(", accZ = ");
Serial.print(inertialAndMagStruct.accZ);
Serial.print(", magX = ");
Serial.print(inertialAndMagStruct.magX);
Serial.print(", magY = ");
Serial.print(inertialAndMagStruct.magY);
Serial.print(", magZ = ");
Serial.print(inertialAndMagStruct.magZ);
Serial.print("\r");
// Print quaternion data as Euler angles
if(ximuReceiver.isQuaternionGetReady()) {
QuaternionStruct quaternionStruct = ximuReceiver.getQuaternion();
Quaternion quaternion = Quaternion(quaternionStruct.w, quaternionStruct.x, quaternionStruct.y, quaternionStruct.z);
EulerAnglesStruct eulerAnglesStruct = quaternion.getEulerAngles();
Serial.print("roll = ");
Serial.print(eulerAnglesStruct.roll);
Serial.print(", pitch = ");
Serial.print(eulerAnglesStruct.pitch);
Serial.print(", yaw = ");
Serial.print(eulerAnglesStruct.yaw);
Serial.print("\r");
// End of file
