X Y graph.
This program is drawing 2 horizontal lines with length proportional to input voltage on PA6 and PA7.
#include <LCD5110_Graph.h>
//LCD5110 myGLCD(8,9,10,12,11);
LCD5110 myGLCD(PA4, PA3, PA2, PA0, PA1);
extern unsigned char SmallFont[];
extern unsigned char TinyFont[];
int LDRpin = PA6;
int LDRpin2 = PA7;
int volt;
char lightString [4];
char lightString2 [4];
String str;
String str2;
int lightIntensity = 0;
int lightIntensity2 = 0;
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  randomSeed(analogRead(PB6));
  randomSeed(analogRead(PB7));
  myGLCD.clrScr();
  myGLCD.update();
  lightIntensity = analogRead(LDRpin);
  lightIntensity2 = analogRead(LDRpin2);
  lightIntensity = map(lightIntensity, 0, 4095, 0, 100);
  lightIntensity2 = map(lightIntensity2, 0, 4095, 0, 100);
  str = String(lightIntensity) + "%";
  str2 = String(lightIntensity2) + "%";
  //str.toCharArray(lightString, 4);
  str.toCharArray(lightString, 6);
  str2.toCharArray(lightString2, 4);
  // high line
  myGLCD.print(lightString2, 2, 17);
  printBar();
  fillBar2(lightIntensity2);
  //low line
  myGLCD.print(lightString, 2, 32);
  printBar();
  fillBar(lightIntensity);
  myGLCD.update();
  delay(100);
void printBar()
  myGLCD.update();
void fillBar(int percent) // X
  percent = map(percent, 0, 100, 2, 81);
  myGLCD.drawLine(2, 44, percent, 44);
void fillBar2(int volt) // Y ?
  volt = map(volt, 0, 100, 2, 81);
  myGLCD.drawLine(2, 40, volt, 40);
To make X -Y graph the code below dotted line need to be modify, my attempt gives this error.
void  printBar(  void fillBar(int percent), void fillBar2(int volt)  )
 myGLCD.drawLine(2, 44, percent, volt); // x1 = 2, y1 = 44, x2 = percent, y2=volt;
Arduino: 1.8.9 (Mac OS X), Board: “Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STLink, 72Mhz (Normal), Smallest (default)”
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino: In function ‘void loop()’:
nokia_xy_4:53:3: error: ‘fillBar2’ was not declared in this scope
nokia_xy_4:58:3: error: ‘fillBar’ was not declared in this scope
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino:58:3: note: suggested alternative: ‘printBar’
printBar
This part of errors comes from modified part of code
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino: In function ‘void printBar(void ()(int), void ()(int))’:
nokia_xy_4:92:3: error: ‘percent’ was not declared in this scope
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino:92:3: note: suggested alternative: ‘_reent’
_reent
exit status 1
void printBar( void fillBar(int percent), void... What’s that?
This line is complete nonsense:
Perhaps you meant:
void  printBar(int percent, int volt )
Maybe you intended to call those two functions?
void  printBar(int percent, int volt)
  fillBar(percent);
  fillBar2(volt);
I know it is incorrect
This shows which elements of code need proper arrangement
void  printBar (   fillBar(int percent),  fillBar2(int volt)  )
error
Arduino: 1.8.9 (Mac OS X), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STLink, 72Mhz (Normal), Smallest (default)"
nokia_xy_4:89:20: error: expected constructor, destructor, or type conversion before ';' token
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino: In function 'void loop()':
nokia_xy_4:53:3: error: 'fillBar2' was not declared in this scope
nokia_xy_4:58:3: error: 'fillBar' was not declared in this scope
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino:58:3: note: suggested alternative: 'printBar'
printBar
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino: At global scope:
nokia_xy_4:89:20: error: variable or field 'printBar' declared void
nokia_xy_4:89:28: error: expected primary-expression before 'int'
nokia_xy_4:89:20: error: 'fillBar' was not declared in this scope
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino:89:20: note: suggested alternative: 'printBar'
printBar
nokia_xy_4:89:52: error: expected primary-expression before 'int'
nokia_xy_4:89:43: error: 'fillBar2' was not declared in this scope
exit status 1
But you’re not calling fillBar in printBar, so why pass the function pointer printBar?
It’s hard to tell what you are trying to do.
//void drawLine(int (fillBar(int percent)), int (fillBar2(int volt)) )
//void  printBar (   fillBar(int percent),  fillBar2(int volt)  )
//void  printBar(int percent, int volt )
  fillBar(percent);
  fillBar2(volt);
error
printBar
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino: In function 'void printBar(void ()(int), void ()(int))':
nokia_xy_4:93:3: error: 'percent' was not declared in this scope
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino:93:3: note: suggested alternative: '_reent'
_reent
exit status 1
You’ve already tried that and it failed, so why try it again?
This error comes from modified part of code, above this line error is from not modified part of code which is working OK in original version
printBar
_reent
exit status 1
Slow down.
Stop throwing mud at the wall in the hope something will stick.
Please describe what you want to do, NOT how you think you should do it.
This is another approach and error
  //void  drawLine(  int percent, int volt   )
  //void  drawLine(  fillBar(int percent), fillBar2(int volt)  )
  void  drawLine( int fillBar,int percent,int fillBar2,int volt  )
  float x1, y1, x2, y2;
  x1 = 2;
  y1 = 40 ;
  x2 =   void fillBar(int percent) // X
  y2 = void fillBar2(int volt) // Y
    myGLCD.drawLine(x1, y1, x2, y2); // x1 = 2, y1 = 40, x2 = percent, y2=volt;
error
…modified part of code
printBar
/Users/kor/Documents/Arduino/nokia_xy_4/nokia_xy_4.ino: In function ‘void drawLine(int, int, int, int)’:
nokia_xy_4:113:10: error: expected primary-expression before ‘void’
nokia_xy_4:120:8: error: expected primary-expression before ‘void’
exit status 1
OK, so “slow down” obviously means something different in your language.
Ask yourself " Why am I trying to assign the non-existent return value from a void function to a variable?"
Line
Left end = x1=2, y1= 40
Right end = x2 = percent, y2 = volt
What has that graph got to do with your problem involving “percent” and “lightintensity”?
I have 2 horizontal lines length of them depends to applied voltage
I need one line
as on the picture, left end = constant ,
right end = variable
X-axis = percent
Y-axis = v
TheMemberFormerlyKnownAsAWOL:
What has that graph got to do with your problem involving "percent" and "lightintensity"?
That are the names from original code, should be changed to Ux and Uy
Here is code with proper names
int LDRpin = PA6;
int LDRpin2 = PA7;
int volt;
String str;
String str2;
int Ux = 0;
int Uy = 0;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.update();
 Ux = analogRead(LDRpin);
Uy = analogRead(LDRpin2);
 Ux  = map(Ux, 0, 4095, 0, 100);
 Uy = map(Uy, 0, 4095, 0, 100);
  str = String(Ux) + "%";
  str2 = String(Uy) + "%";
  // high line
  printBar();
  fillBar2(Uy);
  //low line
  printBar();
  fillBar(Ux);
  myGLCD.update();
  delay(100);
void printBar()
  myGLCD.update();
I don’t understand this code - you will have almost the same values in lightIntensity and lightIntensity2 as you have in Ux and Uy.
Sometimes, they may even be identical.
Ux = voltage applied to PB6
Uy = voltage applied to PB7
That will be Lissajous Figures for DC voltages
tom321:
So what is the significance of the graph in reply #12?
