X27 with stepper library - strange behaviour
I have an X27 168 wired directly to the Arduino pins 8,9,10 and 11. I tried various sample programs on this site but was getting strange behavior, so I have cut the program down to try and understand the interaction between the stepper library and the X27.
This is my code:
#include <Stepper.h>
#define STEPS 315
Stepper myStepper(STEPS, 8, 9, 10, 11);
      Serial.write("Start\n");
      Serial.write("Set speed\n");
      myStepper.setSpeed(100);
      Serial.write("Step -600 first\n");
      myStepper.step(-600);
      Serial.write("Step -600 second\n");
      Serial.write("Step -600 loop\n");
As I understand it, to zero the motor, it should be instructed to step with a value greater than the number of available steps so that it will hit the stop. My first attempt at this told the motor to step -600 but had unpredictable results with a different movement each time I pressed reset or uploaded the program, so I added the second step(-600) and it still behaved erratically, so I added the step(-600) in the loop and this video shows the behavior.
I am trying to create a gauge that fits in a 50mm housing with the pivot near the top, so I cant have the needle swinging so far round
What is an "X27 168"?
Please post a link to its datasheet.
...R
It's a gauge motor:
Do you have inductive kick diodes to protect the Arduino?
If not, don't expect that setup to work more than a few minutes. Sensible people use a motor driver.
My original plan was to use an A4988 driver but I found various postings on the forums to say that the X27 could be driven directly from the Arduino pins and as space is tight, I switched to this option.
I haven't added diodes but will do, however it hasn't failed after a few minutes, I left it running all day yesterday to see if there were any heat issues.
mgb:
You can live for thousands of days but you only die once. Fit the diodes now.
...R
