XBee and Arduino uno
I have a problem that i don't understand. I read a NTC termistor and convert it to temperature with steinhart formula. It seems to work well. I then send this temperature to another combination of XBee and Arduino, same setup. In that end I try to read out the temperature on a Arduino TFT LCD screen but I get only ASCII code. Is it the Bee configuration that is wrong or can/should I convert it in some way? I´m a newbee on arduino, and C programing also, I work normaly with PLC and the 5 IEC languages that is normal there.
Hope for help!
Br. Jan
bug is line 42 and your red wire is not plugged in firmly... not 100% sure thought - just from what I can see
:slight_smile:
joke aside - do you think you shared enough info?
