Xbee and Arduino Yun / Leonardo
Hello everybody, I have an issue with communication between arduinos via Zigbee.
I have an arduino uno with a zigbee setted as router, that sends a string to the network.
The coordinator, that is in the same network, picks up the string and prints it in the serial monitor.
The coordinator is basically an arduino yun/leonardo with a xbee, setted of course as a coordinator.
If I run this sketch on an arduino leonardo, it works fine, it reads what’s incoming from the arduino uno and prints it to the serial. But if I use an arduino yun, instead, nothing happens.
 send like this:
<M:1-S:0>
'<' is for initiate
'>' is for end
M is for machine status, 1 on, 0 off
S is for smoke status, 1 detected, 0 off
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
int MachineStatus = 0;
  Serial1.begin(9600);
  // Read all serial data available, as fast as possible
  while (Serial1.available() > 0)
    char inChar = Serial1.read();
    if (inChar == SOP)
      index = 0;
      inData[index] = '\0';
      started = true;
      ended = false;
      Serial.println("Start detected");
    else if (inChar == EOP)
      ended = true;
      Serial.println("End detected");
      if (index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if (started && ended)
    // The end of packet marker arrived. Process the packet
    Serial.println(inData);
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
Why is that happening? Thanks!
Solved! It seems that the arduino Yun uses the pin 0 to communicate with the Linux Linino. I just moved the tx&rx pins of the xbee from 0 and 1 to pins 10 and 11.
I used this to declare the software serial
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
Can you post the code?
