xbee and arduino
I have a little problem with a xbee shield and an arduino.
The problem is that we havn't been able to get either the xbee shield or the xbee adapter.
That means i've only got the xbee s6B module and an arduino.
I can't get the xbee module to send stuff without the x-ctu program and i can't get it to respond in AT mode or im doing something wrong.
Is it possible that you guys can give me some standard program to configure the xbee module and helping me send stuff from the arduino :smiley:
Right now im just trying to get it connected on the web and getting it to send a request to "http://www.stressknap.dk/input.php?id=1"
The powersource is set to 3,3V to the xbee module
GND on the arduino is set to reset on the arduino
Pin 0 -> RX is connected to TX on the xbee module
Pin 1 -> TX is connected to RX on the xbee module
I cant take a picture of it since this forum only allow 1MB pictures
Digi.com did. It's called X-CTU. Why can't you use that?
You'll need to post link to the XBee(s) that you are using. Most XBees are radios. Radios don't connect to the internet.
PaulS:
x-ctu wont connect to the xbee module
PaulS:
xbee S6B is a wifi module. So it should be able to connect to a router and send a request to the website
