Hello all,
I'm having a problem when using my Xbee Shield in my MEGA 2560. To upload I just move the pins to USB communication. For the antennas talk to each other, I move the pins to XBEE position!
I have a pretty simple code for the receiver antenna and I obtain good values from the sender antenna configured in XCTU!
The problem is when I try to use this piece of code:
if (Serial.available() >= 21) { // Make sure the frame is all there
if (Serial.read() == 0x7E) { // 7E is the start byte
for (int i = 1; i<19; i++) { // Skip ahead to the analog data
byte discardByte = Serial.read();
int analogMSB = Serial.read(); // Read the first analog byte data
int analogLSB = Serial.read(); // Read the second byte
int analogReading = analogLSB + (analogMSB * 256);
Serial.print(analogReading);
in one of my other projects:
Wire.begin();
Serial.print("Initializing SD card...");
pinMode(HCS, OUTPUT);
// MORE TFT STUFF - SEE EXAMPLE SKETCHES
tft.initR(INITR_BLACKTAB); // initialize a ST7735S chip, black tab
//ROTATES DISPLAY 90 DEGREES FOR LANDSCAPE VIEW
tft.setRotation(3);
tft.fillScreen(YELLOW);
// see if the card is present and can be initialized:
if (!SD.begin(sd)) {
Serial.println("Card failed, or not present");
tft.fillScreen(WHITE);
tft.setTextSize(1);
tft.setTextColor(BLACK);
tft.setCursor(30, 40);
tft.print("1) Insert SD CARD");
tft.setCursor(30, 60);
tft.print("2) Reset Energy Box");
usingSD = false;
// while (1) ;
else usingSD = true;
Serial.println("card initialized.");
bmpDraw("images/right.bmp", 35, 45);
// analogWrite(5, 255); //jump "LITE" and Digital pin 5 to dim
delay(1500);
// BLANKS OUT THE SCREEN AND DRAWS THE BLACK BAR
readSDSettings();
Serial.print(TariffType);
Serial.print(enteredValueMaximum);
pinMode(redLedPin, OUTPUT);
pinMode(greenLedPin, OUTPUT);
pinMode(blueLedPin, OUTPUT);
setSyncProvider(RTC.get); // the function to get the time from the RTC
if (timeStatus() != timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time");
//writeSettingsSDInit();
// readSettingsSDInit();
Serial.print(" DATE");
Serial.print("\t");
Serial.print(" HOUR");
Serial.print("\t");
Serial.print("Power (W)");
Serial.print("\t");
Serial.print("Energy (kWh)");
Serial.print("\t");
Serial.print("Money Spent (Eur)");
Serial.print("\t");
Serial.print("Temperature (");
Serial.print((char)247);
Serial.println("C)");
Serial.println("");
// SDLayout();
when I upload the all program, it runs without problems after changing the pins in the Xbee Shield to "XBEE".. the problem is after I reset the arduino... the setup executes until a certain line, and it restarts again from the beginning..never going to the loop!
WHY??
