xBee API Mode Sending Data with Frames
Hi.
I’m trying to make a frame that sends a specified message.
I’m following this article: http://knowledge.digi.com/articles/Knowledge_Base_Article/Calculating-the-Checksum-of-an-API-Packet
So in order to send a message, there must be some calculations and frame must obey the rules otherwise xBee can’t send the message.
Making the LENGTH BYTES is easy. sizeof() function can do it. But i stuck on making CHECKSUM.
My code is following:
byte START_DELIMITER = 0x7E; // Don't change
byte LENGTH_BYTES_1 = 0x00; // Don't change
byte LENGTH_BYTES_0 = 0x00; // Will be changed
byte API_IDENTIFIER = 0x01; // Don't change
byte API_FRAME_ID = 0x01; // Don't change
byte DESTINATION_LOW_1 = 0xFF; // Don't change
byte DESTINATION_LOW_0 = 0xFF; // Don't change
byte OPTION_BYTE = 0x00; // Don't change
byte CHECKSUM = 0x00; // Will be changed
char message[] = "NODE01"; // message
  Serial.begin(57600);
  LENGTH_BYTES_0 = (byte)(sizeof(message));
  CHECKSUM = (byte)(API_IDENTIFIER+API_FRAME_ID+DESTINATION_LOW_1+DESTINATION_LOW_0+OPTION_BYTE+message);
  Serial.write(CHECKSUM);
  delay(5000);
Code is not working.
How can i achieve to the CHECKSUM in the link?
Then i can continue to create to my frame.
Best regards.
The checksum is computed from the bytes in the message, not the address of the message.
