Hi all, I follow the examples of the Xbee-Api and I send two byte to another Xbee.(I have two Xbee S2)
Now I wanna go further, so I want send a String to another XBEE via Api-Mode, I must create more payload? There is a function for do that? The string is long about hundred character, and the receiver must know the send order of character for reconstruct the string. How can I do that?
Thanks
Alessandro
You must change the size of the payload array.
No. It requires that you define the size at compile time.
I don't think that the payload can be that large.
So thanks for your reply.
If I set a payload array size of hundred character the compilation process didn't give any error. Now I can't try with Xbee but I will try in the next days.
For load a string in payoad's array, I use a function, so everything in theory works, when I try I will update this post.
Thanks
Alessandro
reconstruction is not required. Just copying your string to API Data array:
char arr[LEN]={0}; //your string
char *ptr = arr;
memcpy(API.payload.dataArray, ptr, MAX_SIZE);
ptr += MAX_SIZE;
... using a while() loop
Send to Dest-XBee
