Xbee code help
when I run this program I get
stray "" in program
I dont understand
thanks
john
// RECIEVER
byte incomingByte, sensor1, sensor2;
// start serial port at 19200 bps
Serial.begin(19200);
// led pins
pinMode (5, OUTPUT);
pinMode (6, OUTPUT);
if (Serial.available()) { // are there any bytes available on the serial port ???
// assign bytes to the var ‘incomingByte’
incomingByte = Serial.read();
Serial.print(int(incomingByte));
// from now on is pretty clear I guess :slight_smile:
if ((int(incomingByte) == 254)) {
sensor1 = Serial.read();
Serial.print(“Sensor 1 = “);
Serial.print(int(sensor1));
if ((int(incomingByte) == 255)) {
sensor2 = Serial.read();
Serial.print(“ Sensor 2 = “);
Serial.print(int(sensor2));
analogWrite (5, sensor1);
analogWrite (6, sensor2);
Got it
When i cut a paste programs from the web the " quotation
marks are not correct
when i delete and retype the quotation marks
the quotation marks and "Ready!"turn blue.
Serial.println("Ready");
