I'm very sorry for the little information I provided.
XBee XBP24-ZB Coordinator API: ID 444, AP 2, SP 1F4, DH 0, DL FFFF, BD 9600
XBee XBP24-ZB Router API: ID 444, AP 2, SP 1F4, DH 0,DL FFFF, JV 1, BD 9600
Transmitter:
#include <XBee.h>
This example is for Series 2 XBee
Sends a ZB TX request with the value of analogRead(pin5) and checks the status response for success
// create the XBee object
XBee xbee = XBee();
uint8_t payload[] = { 0, 0 };
// SH + SL Address of receiving XBee
XBeeAddress64 addr64 = XBeeAddress64(0x0013a200, 0x403e0f30);
ZBTxRequest zbTx = ZBTxRequest(addr64, payload, sizeof(payload));
ZBTxStatusResponse txStatus = ZBTxStatusResponse();
int pin5 = 0;
int statusLed = 12;
int errorLed = 13;
void flashLed(int pin, int times, int wait) {
for (int i = 0; i < times; i++) {
digitalWrite(pin, HIGH);
delay(wait);
digitalWrite(pin, LOW);
if (i + 1 < times) {
delay(wait);
pinMode(statusLed, OUTPUT);
pinMode(errorLed, OUTPUT);
xbee.setSerial(Serial);
// break down 10-bit reading into two bytes and place in payload
pin5 = analogRead(5);
payload[0] = pin5 >> 8 & 0xff;
payload[1] = pin5 & 0xff;
xbee.send(zbTx);
// flash TX indicator
flashLed(statusLed, 1, 100);
// after sending a tx request, we expect a status response
// wait up to half second for the status response
if (xbee.readPacket(500)) {
// got a response!
// should be a znet tx status
if (xbee.getResponse().getApiId() == ZB_TX_STATUS_RESPONSE) {
xbee.getResponse().getZBTxStatusResponse(txStatus);
// get the delivery status, the fifth byte
if (txStatus.getDeliveryStatus() == SUCCESS) {
// success. time to celebrate
flashLed(statusLed, 5, 50);
// the remote XBee did not receive our packet. is it powered on?
flashLed(errorLed, 3, 500);
} else if (xbee.getResponse().isError()) {
//nss.print("Error reading packet. Error code: ");
//nss.println(xbee.getResponse().getErrorCode());
// local XBee did not provide a timely TX Status Response -- should not happen
flashLed(errorLed, 2, 50);
Receiver:
#include <XBee.h>
Receives a ZB RX packet and sets a PWM value based on packet data.
Error led is flashed if an unexpected packet is received
XBee xbee = XBee();
XBeeResponse response = XBeeResponse();
// create reusable response objects for responses we expect to handle
ZBRxResponse rx = ZBRxResponse();
ModemStatusResponse msr = ModemStatusResponse();
int statusLed = 11;
int errorLed = 12;
int dataLed = 13;
delay(wait);
delay(wait);
pinMode(dataLed, OUTPUT);
// start serial
xbee.begin(Serial);
flashLed(statusLed, 3, 50);
// continuously reads packets, looking for ZB Receive or Modem Status
xbee.readPacket();
if (xbee.getResponse().isAvailable()) {
// got something
if (xbee.getResponse().getApiId() == ZB_RX_RESPONSE) {
// got a zb rx packet
// now fill our zb rx class
xbee.getResponse().getZBRxResponse(rx);
if (rx.getOption() == ZB_PACKET_ACKNOWLEDGED) {
// the sender got an ACK
flashLed(statusLed, 10, 10);
// we got it (obviously) but sender didn't get an ACK
flashLed(errorLed, 2, 20);
// set dataLed PWM to value of the first byte in the data
analogWrite(dataLed, rx.getData(0));
} else if (xbee.getResponse().getApiId() == MODEM_STATUS_RESPONSE) {
xbee.getResponse().getModemStatusResponse(msr);
// the local XBee sends this response on certain events, like association/dissociation
if (msr.getStatus() == ASSOCIATED) {
// yay this is great. flash led
} else if (msr.getStatus() == DISASSOCIATED) {
// this is awful.. flash led to show our discontent
flashLed(errorLed, 10, 10);
// another status
flashLed(statusLed, 5, 10);
// not something we were expecting
flashLed(errorLed, 1, 25);
I use the XBee Shield to connect Arduinos with XBees
Transmitter has Pot to A5, Receiver has 3 LEDs to D11, D12, D13
Thank you
