Are you running the Zigbee firmware on the Xbee or something else?
Your code assumes "transparent mode" but the Zigbee firmware on the Xbee doesn't have a transparent mode.
Correction: For S2B
"RF modules that contain the following firmware versions will support Transparent Mode:
20xx (AT coordinator), 22xx (AT router), and 28xx (AT end device)."
Im running it on an arduino. I have 2 xbee pro s2b's with a shield. Ive routed the xbee serials to pis 2 and 3 using cables. This was the setup we used in uni where I first messed with arduino a bit. I am following the same setup and info, but cant get it to work. I have seen that they communicate using xctu so I know they are able to comunicate. Just can't figure out where I am going wrong or what I am missing.
I have actually worked it out. I used a different shield and sent the data via Serial. Worked straight away. So there was something with the previous shield. I think it works, just something I maybe have not understood about it. But it works perfectly now. Time to mess with a few things. Thnk you for helping me out
Forgot to mention. The Equipment, settings and firmware were: -
The Router:
-- equipment --
Board: Arduino UNO R3
Shield: libelium ArduinoXBee v1.1
Adapter/programmer: ICStation XBee USB Adapter
Wireless RF module: XBee pro S2B XBP24BZPIT
--XBee settings--
Family: XBP24BZ7
Functions: ZigBee Router AT
Firmware ver: 22A7
