XBee communication
Hi
I am trying to make this program work but having trouble
I have two arduino with xbee shield and xbee series 2 modules.
Both are configure like in this page http://code.google.com/p/xbee-api/wiki/XBeeConfiguration
So one coordinator and one end point both api and both AP=2
test the configuration and it work.
Now I have this program on my coordinator
//Programme pour COORDINATEUR
#include <XBee.h>
#define TERM_CHAR '\n'
#define BUF_LEN   30
XBee xbee = XBee();
XBeeResponse response = XBeeResponse();
// create reusable response objects for responses we expect to handle
ZBRxResponse rx = ZBRxResponse();
ModemStatusResponse msr = ModemStatusResponse();
char ReceivedData[10];
void ReceiveData()
  xbee.readPacket();
    if (xbee.getResponse().isAvailable()) {
      // got something
      if (xbee.getResponse().getApiId() == ZB_RX_RESPONSE) {
        // got a zb rx packet
        // now fill our zb rx class
        xbee.getResponse().getZBRxResponse(rx);
        if (rx.getOption() == ZB_PACKET_ACKNOWLEDGED) {
            // the sender got an ACK
            // we got it (obviously) but sender didn't get an ACK
        // set dataLed PWM to value of the first byte in the data
        for(int i=0; i < rx.getDataLength(); i++) {
           ReceivedData[i] = (char)rx.getData(i);
        Serial.println(ReceivedData);
      } else if (xbee.getResponse().getApiId() == MODEM_STATUS_RESPONSE) {
        xbee.getResponse().getModemStatusResponse(msr);
        // the local XBee sends this response on certain events, like association/dissociation
        if (msr.getStatus() == ASSOCIATED) {
          // yay this is great.  flash led
          Serial.print("ASSOCIATED");
        } else if (msr.getStatus() == DISASSOCIATED) {
          // this is awful.. flash led to show our discontent
          Serial.print("DISASSOCIATED");
          // another status
      	// not something we were expecting
    } else if (xbee.getResponse().isError()) {
      Serial.print("Error reading packet.  Error code: ");
      Serial.println(xbee.getResponse().getErrorCode());
void SendData (char SendString[], String Destination)
  char payload[10];
  strncpy(payload, SendString, 9);
  * Sh – 13A200 Sl – 408AD157 Coordinateur
  * Sh – 13A200 Sl – 408AD159 Pasteur
  * Sh – 13A200 Sl – 4081A8ED Salle 1
  XBeeAddress64 addr64 = XBeeAddress64(0x13A200, 0x4081A8ED);
//  if (Destination == "SALLE1")
//    addr64 = XBeeAddress64(0x13A200, 0x4081A8ED);
  // SH + SL Address of receiving XBee
  ZBTxRequest zbTx = ZBTxRequest(addr64, (uint8_t*) (payload), sizeof(payload));
  ZBTxStatusResponse txStatus = ZBTxStatusResponse();
  xbee.send(zbTx);
  Serial.println ("Sent");
  // after sending a tx request, we expect a status response
  // wait up to half second for the status response
  if (xbee.readPacket(500)) {
    // got a response!
    // should be a znet tx status
    if (xbee.getResponse().getApiId() == ZB_TX_STATUS_RESPONSE) {
      xbee.getResponse().getZBTxStatusResponse(txStatus);
      // get the delivery status, the fifth byte
      if (txStatus.getDeliveryStatus() == SUCCESS) {
        // success.  time to celebrate
        Serial.println ("Success tx");
        // the remote XBee did not receive our packet. is it powered on?
    //nss.print("Error reading packet.  Error code: ");
    //nss.println(xbee.getResponse().getErrorCode());
    // local XBee did not provide a timely TX Status Response -- should not happen
int i;
char incomingChar, buf[BUF_LEN];
String XBeeDestination;
  // start serial
  xbee.begin(9600);
// continuously reads packets, looking for ZB Receive or Modem Status
  ReceiveData();
  if(Serial.available())
          Serial.println ("Serial avail");
         //clean buffer
         memset(buf,'\0',BUF_LEN); i = 0;
         // read incoming message
         while(Serial.available())
           incomingChar = (char) Serial.read();
           if(incomingChar != TERM_CHAR && i != BUF_LEN)
              buf[i++] = incomingChar;
         delay(1); // wait for another byte
//         if(strcmp(buf,"SALLE1") == 0)
//            XBeeDestination = "SALLE1";
         if(strcmp(ReceivedData,"LedOn") == 0)
            SendData("LedOn" ,XBeeDestination); //Power Led Off
            Serial.println ("LedOn");
         if(strcmp(ReceivedData,"LedOff") == 0)
            SendData("LedOff" ,XBeeDestination); //Power Led Off
            Serial.println ("LedOff");
and this on the end device
//Programme pour salle 1
#include <XBee.h>
// create the XBee object
XBee xbee = XBee();
boolean ReceiveData()
  xbee.readPacket();
      // got something
        return true;
          // another status
void SendData (char SendString[])
  char payload[10];
  XBeeAddress64 addr64 = XBeeAddress64(0x0013a200, 0x408AD157);
  xbee.send(zbTx);
    // got a response!
  pinMode(13, OUTPUT);
  xbee.begin(9600);
  if (ReceiveData() == true)
            digitalWrite(13,HIGH); //Power Led Off
            digitalWrite(13,LOW); //Power Led Off
  char temp[] = "test";
  SendData(temp);
  delay(3000);
I do receive the test message on the coordinator but from my computer plug to the usb of the coordinator I am not able to make the led tun on on the end device.
How come that my command sent form the pc are not even going in the if(Serial.available()) is it because the arduino uno have only one com port and I need a
mega arduino or can i do something about it and make it work
any help would be appreciated.
Which XBee shield? How are the switches/jumpers set?
What do you see in the 2 serial monitor windows?
