The problem is that the coordinator node receives back each message it sends (even if it is the only node in the network).
The destination address is configured correctly before sending the packets.
I think this is due to the DL and DH configuration of the Coordinator node, which currently is broadcast (DL=0xFFFF, DH=0x0000) as it was forced this way by X-CTU.
How could I send unicast messages from the coordinator to a certain node without receiving them back?
Thanks.
I use series 2 xbees and I can set the destination address to anything I want using XCTU. I don't use the libraries since I don't want to hook the xbee to the hardware serial port so I can't help you with a library problem. However, I don't ever receive back what I send, even if I broadcast it. Are you sure you're not receiving the transmit status frame? That comes back to tell you that the message got sent.
In API mode, the destination address (whether broadcast or other) is specified in the Transmit Request frame, I'm not aware that the DH and DL settings even come into play.
draythomp:
With the lastest version of xbee-arduino libraries (available as the latest svn update), you can use a NewSoftSerial object to manage the serial communication, so you can use any digital pin you want! This is what I am doing too, using digital pins 6 and 7 for serial communication with the XBee module.
That would be the behavior I would expect too! Anyway I am still receiving a frame with Type-ID 0x90!
I set mine up for XB24-ZB and the ZIGBEE COORDINATOR API version 2170 and haven't gotten an echo like you're describing. I'll try to figure out how to get the library you're talking about to try. There's a slim possibility of it being a library thing.
That won't even support the multiple usart ports on the mega board. I hate having to remember to unplug the XBee each time I try to download data to the arduino.
