XBee data with random -38 and -35 values
Hi all,
I am working on a project for Maker Faire this year as part of the Atmel booth, this part is basically a controller that controls a robot. One side has a rotary encoder with an XBee, NeoPixel ring, and the other is an XBee plus a ZumoBot (Pololu). XBee settings are correct, Series 1 directly to one another. I have successfully coded the Rotary encoder, NeoPixel ring, and FuzzBot, with the data sent via XBee being mapped (with the map() function) from 0-9, so it is a two-digit repeating data stream that the XBee should be receiving.
However, when I use a Serial Echo program (prints whatever it's receiving basically, with no complex functions at all), the numbers come out fine, so the problem isn't in the XBees is my understanding. I followed an XBee tutorial from Jeremy Blum, but the video said he was using a pre Arduino 1.0 version of the software. The part of the code: Serial.read() - '0'; he said was to convert the data into an integer, but I thought that was what I was doing before. Then, I saw that he had Serial.flush() at the end of his code (which is not supported in 1.0), and I think that is where the problems are in the code.
Any help?
Thanks,
q
The code below is for the Bot:
/*  MFBA '14 Bot (NeoPixel Controller)
  Uses FuzzBot + mount with XBee and LED's, received by the Neo-
  Pixel controller board.
  created 5.4.14
  made by Quin Etnyre
  kudos to Bildr, Adafruit
#include <ZumoMotors.h>
ZumoMotors motors;
int turnVal;
int potVal;
  while(Serial.available() == 0);
   int turnVal = Serial.read() - '0';
   int potVal = Serial.read() - '0';
   Serial.print(turnVal);
   Serial.println(potVal);
  int speedVal = map(potVal, 0, 9, 0, 5);
  switch (turnVal) {
    case 1:
      motors.setLeftSpeed(9*speedVal);
      motors.setRightSpeed(speedVal);
      Serial.println("1");
      delay(2);
      break;
    case 2:
      motors.setLeftSpeed(8*speedVal);
      motors.setRightSpeed(2*speedVal);
      delay(2);
      break;
    case 3:
      motors.setLeftSpeed(7*speedVal);
      motors.setRightSpeed(3*speedVal);
      delay(2);
      break;
    case 4:
      motors.setLeftSpeed(6*speedVal);
      motors.setRightSpeed(4*speedVal);
      delay(2);
      break;
    case 5:
      motors.setLeftSpeed(5*speedVal);
      motors.setRightSpeed(5*speedVal);
      delay(2);
      break;
    case 6:
      motors.setLeftSpeed(4*speedVal);
      motors.setRightSpeed(6*speedVal);
      delay(2);
      break;
    case 7:
      motors.setLeftSpeed(3*speedVal);
      motors.setRightSpeed(7*speedVal);
      delay(2);
      break;
    case 8:
      motors.setLeftSpeed(2*speedVal);
      motors.setRightSpeed(8*speedVal);
      delay(2);
      break;
    case 9:
      motors.setLeftSpeed(speedVal);
      motors.setRightSpeed(9*speedVal);
      delay(2);
      break;
The code below is for the controller:
/* MFBA Controller
   Using NeoPixel Ring (14) x2, rotary encoder (SFE, R/G),
   slider pot (sm/med).
   created 5.4.14
   made by Quin Etnyre
#include <Adafruit_NeoPixel.h>
#define PIN 4 // NeoPixel Pin #
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(16, PIN); //x16
uint32_t color  = 0xFFA500; // Start 'Qtechknow' Green
//these pins can not be changed 2/3 are special pins
int encoderPin1 = 2;
int encoderPin2 = 3;
volatile int lastEncoded = 0;
volatile long encoderValue = 0;
long lastencoderValue = 0;
int lastMSB = 0;
int lastLSB = 0;
int sensorValue;  // integer for potentiometer
  Serial.begin (9600);
  pinMode(encoderPin1, INPUT);
  pinMode(encoderPin2, INPUT);
  digitalWrite(encoderPin1, HIGH); //turn pullup resistor on
  digitalWrite(encoderPin2, HIGH); //turn pullup resistor on
  //call updateEncoder() when any high/low changed seen
  //on interrupt 0 (pin 2), or interrupt 1 (pin 3)
  attachInterrupt(0, updateEncoder, CHANGE);
  attachInterrupt(1, updateEncoder, CHANGE);
  pixels.begin();
  pixels.setBrightness(60); // 1/3 brightness
void loop(){
  sensorValue=analogRead(0); // slider pot
  int newValue = abs(encoderValue);
  int finalValue = map(newValue, 300, 0, 0, 15);
  pixels.setPixelColor(finalValue-1, 0);
  pixels.setPixelColor(finalValue+3, 0);
  pixels.setPixelColor(finalValue, color);
  pixels.setPixelColor(finalValue+1, color);
  pixels.setPixelColor(finalValue+2, color);
  pixels.show();
  int printVal = map(finalValue, 15, 0, 0, 9);
  int printPot = map(sensorValue, 0, 1023, 0, 9);
  Serial.print(printVal);
  Serial.println(printPot);
void updateEncoder(){
  int MSB = digitalRead(encoderPin1); //MSB = most significant bit
  int LSB = digitalRead(encoderPin2); //LSB = least significant bit
  int encoded = (MSB << 1) |LSB; //converting the 2 pin value to single number
  int sum  = (lastEncoded << 2) | encoded; //adding it to the previous encoded value
  if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderValue ++;
  if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderValue --;
  lastEncoded = encoded; //store this value for next time
And here is the weird output I've been getting from the Bot's side's XBee output:
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
6-35
-387
67
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
6-35
-38-35
-38-35
-387
67
6-35
-387
67
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
67
67
6-35
-387
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
67
6-35
-38-35
-387
6-35
-387
67
6-35
-387
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
6-35
-38-35
-387
67
67
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
6-35
-387
6-35
-387
67
67
6-35
-387
67
67
6-35
-38-35
Hi all,
Any help?
Thanks,
q
  created 5.4.14
  made by Quin Etnyre
ZumoMotors motors;
int turnVal;
int potVal;
  switch (turnVal) {
    case 1:
      delay(2);
      break;
    case 2:
      delay(2);
      break;
    case 3:
      delay(2);
      break;
    case 4:
      delay(2);
      break;
    case 5:
      delay(2);
      break;
    case 6:
      delay(2);
      break;
    case 7:
      delay(2);
      break;
    case 8:
      delay(2);
      break;
    case 9:
      delay(2);
      break;
/* MFBA Controller
   created 5.4.14
   made by Quin Etnyre
int lastMSB = 0;
int lastLSB = 0;
  pixels.begin();
void loop(){
  pixels.show();
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
6-35
-387
67
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
6-35
-38-35
-38-35
-387
67
6-35
-387
67
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
67
67
6-35
-387
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
67
6-35
-38-35
-387
6-35
-387
67
6-35
-387
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
6-35
-38-35
-387
67
67
6-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-38-35
-387
6-35
-387
6-35
-387
67
67
6-35
-387
67
67
6-35
-38-35
Those -35 and -38 are when it is not getting any data.
The calculation char-'0' will calculate an integer equal to the number of spots in the ascii table between the character you got, and the character '0'. This is only a meaningful calculation if the character you got is actually in the range '0' to '9'.
An ascii '0' is 48 decimal, so if you calculation gives you -35 or -38, you actually got a character with the numerical value of 13 or 10 decimal, which a quick look at the ascii chart, are "carriage return" and "line feed".
You probably want to change your logic to ignore those, or only to process you input if it is actually a character '0' to '9'
This is a bigger problem, here. You have no serial input characters available, but you are trying to read two of them ? That's just plain wrong.
No, you have at least one character available, but read two of them.
Thanks for the replies. After the first response by michinyon, I took out the ln part of the Serial.println, and it worked great, but of course since the data was not separated by anything at all, (0 and 6 would come out as 606060606060 which could be interpreted as 6, and 0, or 0, and 6), I added in something to show what data was what. I added in a '~' before one of the values, and none of the values excede single digits, so then you could tell which piece of data was what. Although, there is occasionally an extra '678' somewhere in there which is throwing the bot off. This then makes the robot less smooth at moving, stuttering a lot, which will eventually burn out the motors. I am looking to make the FuzzBot move more smoothly (somewhere in the code), any ideas?
I have adjusted the code again, and here is the new code for the Bots:
  created 5.4.14
  made by Quin Etnyre
ZumoMotors motors;
int turnVal;
int potVal;
int lastTurnVal;
int thirdVal;
int fourthVal;
  while(Serial.available()) {
    if(Serial.read() == '~') {
  int speedVal = map(potVal, 0, 9, 0, 25);
  switch (turnVal) {
    case 1:
    if(lastTurnVal == 1) {
      if(thirdVal == 1) {
        if(fourthVal == 1) {
        break;
      break;
    case 2:
    if(lastTurnVal == 2) {
      if(thirdVal == 2) {
        if(fourthVal == 2) {
        break;
      break;
    case 3:
    if(lastTurnVal == 3) {
      if(thirdVal == 3) {
        if(fourthVal == 3) {
        break;
      break;
    case 4:
    if(lastTurnVal == 4) {
      if(thirdVal == 4) {
        if(fourthVal == 4) {
        break;
      break;
    case 5:
    if(lastTurnVal == 5) {
      if(thirdVal == 5) {
        if(fourthVal == 5) {
        break;
      break;
    case 6:
    if(lastTurnVal == 6) {
      if(thirdVal == 6) {
        if(fourthVal == 6) {
        break;
      break;
    case 7:
    if(lastTurnVal == 7) {
      if(thirdVal == 7) {
        if(fourthVal == 7) {
        break;
      break;
    case 8:
    if(lastTurnVal == 8) {
      if(thirdVal == 8) {
        if(fourthVal == 8) {
        break;
      break;
    case 9:
    if(lastTurnVal == 9) {
      if(thirdVal == 9) {
        if(fourthVal == 9) {
        break;
      break;
      thirdVal = lastTurnVal;
      lastTurnVal = turnVal;
And here is the newest controller code:
/* MFBA Controller
   created 5.4.14
   made by Quin Etnyre
#include <SoftwareSerial.h>
int lastMSB = 0;
int lastLSB = 0;
SoftwareSerial Serial7Segment(7, 8); //RX pin, TX pin
int cycles = 0;
int runClock = HIGH;
int i = 3000;
  Serial7Segment.begin(9600); //Talk to the Serial7Segment at 9600 bps
  Serial7Segment.write('v'); //Reset the display - this forces the cursor to return to the beginning of the display
  pixels.begin();
void loop(){
  pixels.show();
  int printVal = map(newValue, 0, 300, 0, 9);
  Serial.write(0x7E);
  Serial.print(printPot);
And here is the data I'm getting from the bot's side after I try and decode the data:
46
46
46
46
678
46
678
46
678
46
678
46
678
46
678
46
678
46
46
46
46
46
Thanks,
Quin
